Super fast, low noise phono preamp - diyAudio
Old 30th May 2004, 07:46 PM   #1
Default Super fast, low noise phono preamp
Hi DIYers
This is a picture of my DIY Phono Preamp. Schematics as shown is MC section.
Value of resistors R7, R8, R12 and of capacitors C2 and C5 are critical components. It's important to match to original values as close as possible. Capacitor C5 is better to be MKP (poliprophylene). Potty P1 isn't necessary, but it's adjusted on DC component before resistor R7, to be as small as is possible. Potty P2 have to be adjusted on DC offset to be 0.That's simply to make. In the case, we want greater gain, R11 have to be smallest value. With value of 220 ohms, we obtain 6dB more on gain.
I expect your suggestions.
Best regards, Dioklecijan
Old 30th May 2004, 07:49 PM   #2
Inside
Old 30th May 2004, 07:51 PM   #3
Final front
Old 31st May 2004, 06:30 PM   #4
Electrons are yellow and more is better!
peranders's Avatar
Nice work! Nice looking hand drawn schematic also.
Just wondering about C5 When You have gain more than 5-10 or this capacitors isn't very necessary, my opinion, but what is your reason for it?. Have you seen my LT1115/1028 vinyl amp.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 31st May 2004, 06:43 PM   #5
jam is offline jam  United States
jam's Avatar
Default Peranders...............
at it again.....................
Old 31st May 2004, 07:21 PM   #6
Congratulation Peranders,
you see exactly what I want.
In this case with LT1028 and OPA627 is not very necessary to put capacitor C5 here, but don’t forget there is MM section with OPA 2134 and more offset without trim.
I see your phono and other works before. Very nice! Beautiful works.
Old 31st May 2004, 07:25 PM   #7
LT1028 or LT1115 or AD797 what is your experience?
Old 31st May 2004, 07:58 PM   #8
peranders's Avatar
LT1115 and LT1028 is the same IC but with different DC parameters.... and different price. I haven't tested AD797 yet.
Old 31st May 2004, 08:23 PM   #9
Look this:
Upgrade version with unique SRPP J-FET output stage
http://www.hiendfi.com/modules.php?n...rticle&sid=102
Old 31st May 2004, 08:29 PM   #10
analog_sa's Avatar
I have mixed feelings about the split passive/actibve riaa. It never ever sounded good to me compared to either passive/split passive or active correction. Maybe i was just unlucky with that topology.
Super Audiophile Phono-Stage - Battery Powered GlidingDutchman Analog Line Level 41 6th November 2008 10:23 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
help needed with noise in phono preamp duderduderini Tubes / Valves 22 31st May 2007 03:35 PM
Noise on the RIAA phono preAmp diarav Chip Amps 3 23rd March 2007 05:27 AM
Copyright ©1999-2017 diyAudio
