Old 29th May 2004, 03:36 PM   #1
bonsai171's Avatar
Default help setting up record player please!
i'm having trouble setting up my record player w/ an nad preamp. It has a phono stage, but there are multiple settings on the back, and i don't know which ones to choose. These settings are switches: first either mm or mc (not sure which, but the turntable is a philips), and the second says either 100p, 220p, or 320p. Which choices would be right for this record player?? Unfortunately i don't have manuals for either! Many thanks!
Dave
Old 29th May 2004, 03:47 PM   #2
Its completely likely that only the MM setting will be appropriate.
For the capacitive loading you should start with 100p.
You can try the other two settings without harm, they will
effect extreme treble response and you should choose the
best sounding setting by ear, the effect is very dependent
on the cartridge fitted to the turntable and the turntables
lead capacitance, if this is high there will be barely any
difference between the 100p and 200p settings.
sreten.
Old 29th May 2004, 04:42 PM   #3
bonsai171's Avatar
Default it works!!
Sreten,
It works! The sound is really good. You must have been right on the money there. Thanks a bunch The 100p setting seems to sound best.
Dave
zenith mlt 15 console record player problem tim614 Tubes / Valves 14 6th July 2008 04:33 AM
Duosonic 40's era record player whodatpat Tubes / Valves 20 20th December 2007 02:32 AM
Well Tempered Record Player cartridge johngalt47 Analogue Source 11 21st May 2006 06:07 AM
New and Cheap Record Player rtarbell Analogue Source 1 27th February 2006 05:32 PM
setting up a philips record player... manlyasgolf Everything Else 0 4th October 2004 09:33 PM
Page generated in 0.07326 seconds (72.14% PHP - 27.86% MySQL) with 10 queries
