Old 25th May 2004, 08:29 AM   #1
ebijma is offline ebijma  Netherlands
ebijma's Avatar
Default Circuit diagram for the Philips F7430
Hello everbody,
Can anyone help me with the Philips F7430?
The arm lift doesn't work, and i think it has to do with the electronics.
So if anyone can help me get the manual and/or circuit diagram that would
be great.
Old 15th July 2007, 02:53 PM   #2
afi is offline afi  Netherlands
I've got the same problem as you. The armlift will not descend if i want to play a LP. Did you have allready solve the problem or do you have a sort of manual/circuit diagram? I will pleased to hear from you.
Old 24th March 2010, 10:20 AM   #3
Default Philips F7430 Service Manual
If someone is searching for F7430 Service Manual, Email me to following address:
giancarlopell@freepass.it
Old 29th December 2010, 07:41 PM   #4
I am interested in a solution. Please let me know.
Old 3rd September 2012, 01:32 PM   #5
I know that this is an old thread, but... anyone has the schematics or other info on this turntable,
david
Old 18th September 2012, 09:29 AM   #6
Default I do have the usermanual and servicemanual
If you still want them I have both.
Textpart in servicemanual is in Dutch but schematics and so on are useable in any language.
I could translate Dutch questions to English.
Usermanual is multilanguage.
I just repaired one... Arm didn't go down.
Cause bad contacts in the Processor connector.
I exchanged the connector for a good one and player is OK again.
Greetings, Peter
Old 18th September 2012, 12:50 PM   #7
Greetings, Peter
Hi Peter,
I just receibed a used one, and the tonearm is not lowering also.
When opening the box I half broke the tray in/out mechanism, which I hope I have repaired.
I'd appreciate it if you could send me an indication of the faulty part (how to identify it on the circuit). I don't speak dutch at all.
I would also appreciate any aditional info, for example on how to change the headshell, as the tip in mine seems broken or unexistant.
By the way, do you think that this model is worth the effort of repairing?
Would you recomend any cartridges?
I was considering to change the stock platter for a heavier one. Could it be an improvement
my email is despinos at yahoo.com
Thanks anyway and regards
David
Circuit Diagram epacor Parts 1 3rd February 2007 06:42 AM
Help! circuit diagram vodaTube Tubes / Valves 0 8th July 2005 06:49 AM
ML 383 circuit diagram leigong Solid State 0 29th June 2004 02:13 PM
Philips CD960 Circuit diagram mozfet Digital Source 3 1st February 2003 11:57 AM
Copyright ©1999-2013 diyAudio
