| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#391 | |
#392 |
bearing spacing is 33mm or ~1 3/8". Effective length is 80mm or ~3 1/8". I guessed those numbers from looking at the pics....
Am I in the ballpark? Fran |
#393 |
mmm. So I went back and flushed out the bearings, spun them with the compressor. One of them kinda fell apart as it was spinning - one of the retaining clips just fell out. My issue may just be really crap bearings.
Fran |
#394 | |
Hi Doug,
I have been having a lot of trouble trying to type answers to postings on DIY Audio. The cursor keeps moving around and shifting the positiion of words or partial words elsewhere on the page. I find my entries getting lost or deleted and other strange stuff. Thought it could be the wireless mouse sending spurious signals, so I tried a USB mouse to no avail. Right now I'm on word pad and having no trouble at all. Will copy and paste this to the forum if that works. Your comments on the LT arm being ready for polishing up to something more than looking like a "little thing" hit home with what has been my thinking from the day one. In fact the "little thing" put me off building a LT for a long time. I'm about ready to build a more or less final model. My TT is made of grey Corian with a white Corian platter. I intend to use the same materials for the LT arm and scale the parts where possible to give an integrated appearance. The base will be like an arm board, curved to follow the platter and into a corner and side edge of the plinth. Wish me luck. In a reply to Fran I mentioned to you that I had just ordered ceramic bearings. I was able to get 4x10x4 mm bearings which are the same size as I am using in SS abec 7 bearings. So I will be able to make a direct comparison. I note that Acer-racer delivers these bearings lubricated with a low viscocity synthetic oil. Did you use yours as delivered or did you flush them out? I'm really looking forward to trying ceramics. When we feel that we have a matured and reproducible LT, maybe we should distill the process into a LT CookBook like the loudspeaker design cookbook, so future builders needn't dig through all our postings and efforts to reproduce one. But there is much fun and much to be learned by digging deeply into the forum and this thread. I tried to give Fran some help with his hunting problem. My hunting seems to be corrected, but I'm not really sure just what fixed it. Anything you can suggest or comment on would help him and possibly shed some light for all of us. Rgds, BillG Quote:
#395 |
I wonder if the cylindrical tube of the Opus 3 allows for a fudge of torque analogous to the "crabbing" of servo assisted LTs. 90 degree reactions are intrinsic to Newtonian structures, and attempts to achieve 100% rigidity are doomed. I'm thinking of the Millennium bridge in London which had to have dampers installed after the grand opening resulted in serious oscillation. The original is sometimes the best.
#396 |
Fran, Couldn't tell whose pics you were looking at. DTUT's or mine. Mine measure 46.5mm spacing and 107mm apex of track to stylus. These numbers taken with hand held caliper held close to but not precisely against the arm. So yes you are in the ball park considering the pics are small and all taken at oblique angles. Sorry to hear your bearing blew up. Cut down the air pressure next time. Really, that spacer shouldn't have fallen apart. Get a refund or a replacement.
BillG |
#397 |
Thanks guys. I ordered some new ceramic ones from acerracing.com, I'll try those when the land here.
In the meantime, I need to put the finishing touches to my schroder arm, which is up playing and sounding pretty good tonight!! Fran |
#398 |
Hi Fran, Doug and others,
My 4x10x4 ceramics came today. Installed them tonight and spent the rest of the evening listening to records. Brilliant! First I flushed them out by spinning them slowly by hand in an acetone bath. then blew them out with compressed air and repeated the wash. There was a surprising amount of stuff that flushed out so the second rinse was in clean fluid. Acerracer says the bearings are lubed with thin silicone(check this) oil not grease so I didn't remove the seals. Then mounted them in place of the abec7's, aligned the arm again and the rest is listening to it. It tracks perfectly. The sound is no different than with the old bearings. It seems to be tracking at a lower stylus pressure, have to measure that. Like you Doug, I won't be going back to all steel bearings. I didn't want to buy a tube of 10, so I settled on 2 pcs. Perhaps cherry picking could have found even better ones. Will have to ask what the ABEC rating is. I think there may be a bit more radial play, and that may be to our advantage. Did a lot of watching the cart to check for hunting. There is none visible but I'll check more carefully. Now to make a pretty arm. I'm a happy guy tonight. BillG |
#399 |
Excellent news!
Fran |
#400 |
New bearings arrived today - and yes they are a massive improvement! I flushed them out as normal and I did remove the seals - they ran much freer without those. I quickly mounted them up and tried them out..... and it works!!
Now, its not perfect yet, I think a bit more tweaking is needed, I need to polish the outside of the bearings, plus refine the mounting for the slide, plus I think I can shave a few grams off the mass too. I made a short vid and loaded it to youtube. Quality ain't brilliant, but you can get the idea. I shot some of the cart running in the lead out groove to show both the deflection on the stylus, and then again to show the carriage movement. The deck is just a junker with a warped platter, plus the record is not great either, so its a test! Link: VIDEO0095.3gp - YouTube Fran |
| The Ikea curtain rail air parallel tracking tonearm! | ericpeters | Analogue Source | 169 | 15th October 2011 01:08 AM |
| My take on TPA's Opus DAC | orthoefer | Digital Source | 9 | 18th April 2008 01:51 PM |
| Opus Dei! | mikeks | Music | 6 | 25th January 2005 10:37 PM |
| Parallel amps & Parallel Voice coils? | officeboy | Multi-Way | 7 | 26th May 2004 07:12 PM |
