Opus 3 Cantus parallel tracking arm
Old 7th May 2010, 01:03 AM   #131
moray james is offline moray james  Canada
I did not notice that small problem either but I was thinking about two small v-grove bearings to make up a composite bearing for each of the two bearings you used. So there would be a separate bearing to roll on each rod.
moray james
Old 7th May 2010, 01:35 AM   #132
directdriver is offline directdriver  United States
directdriver's Avatar
Sheldon: "I may misunderstand your intent, but it looks like the bearing would roll on one rod and slide on other."
It would require something like this. A triangle carriage on two rods, probably too heavy.
Old 7th May 2010, 02:20 AM   #133
Nanook is offline Nanook  Canada
Nanook's Avatar
Default here's a sketch of my previous post
as the title says....
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 7th May 2010, 03:45 AM   #134
dtut is offline dtut  United States
Good Evening, all,
Nanook: Would larger bearings maybe ride over dirt and track imperfections better than tiny ones? Think 13" wheels compared to 17". Are cupped single bearings available?
DD: Making the tricycle light is possible. The rails will have to be aligned fairly precisely so the tricycle rolls freely but is stable. It's doable. Attractive idea.
Frank DeG: I'd appreciated any light you can shed on how to deal with resonances. The idea of a mechanical diode is intriguing and I'd like to hear more.
Doug Tuthill
Old 7th May 2010, 04:00 AM   #135
moray james:can you post a link or pictures of Tom Fletcher's Radial tracking unipivot arm?
I disassembled a Nottingham unipivot arm once and saw the inner working of its design. Inside the bearing housing, there are two metal rods, below the single pivot point, that park on a ball bearing that allows the arm to move horizontally and vertically but inhibit azimuth movement. There are many hybrid unipivot arms out there that use a ball bearing to stabilize the azimuth, like the Basis Vector, Continuum Copperhead, Graham Phantom, etc.. but they all have only two contact points, whereas the Nottingham has three.
The one arm that is closest in design concept is the clever Simon Yorke tonearm (Now, there's a designer whom I really admire!) that uses no ball bearing at all but uses a teflon sleeve with a guiding plate. Check picture of the tonearm from the S-9 model record player. I think the SY design is much simpler and more elegant. I also like his Bauhaus styling. Sorry to be off topic again. My mind is always at tangents. :-)
Old 7th May 2010, 04:41 AM   #136
dtut: "Making the tricycle light is possible. The rails will have to be aligned fairly precisely so the tricycle rolls freely but is stable."
Maybe something like this, by having the two rods touching each other to avoid alignment problem or simply replace the two rods with one flat piece.
Old 7th May 2010, 04:52 AM   #137
Let's steal some DIY ideas from another forum!
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=60946 in Norwegian
Old 7th May 2010, 12:22 PM   #138
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Here's a link to what I was refering to:
GOLDMUND - Technology - Mechanical Grounding
Frank
Old 7th May 2010, 03:53 PM   #139
wjlamp is offline wjlamp  Greece
I follow your thinking.
Toying with the idea of a parallel tonearm,what about using your two bearings ,running on a triangular rod. Hanging from the bearing carrier ,making a T , two additional bearings on the vertical rod,with the armwand between them,like in radial tonearms? The main weight,will be below main bearings,and the arm will follow the ups and downs of warped discs.
B.L
Old 7th May 2010, 06:18 PM   #140
Speaking of triangle, here's a disassembled Souther arm that shows the triangular carriage with rollers on two quartz rails. I think having an extra roller complicates thing but at the same time it limits only to horizontal movement that allows manipulation of vertical bearing. It has plus and minus, no free lunch again.
Close up of the Souther successor, Clearaudio arm.
And here's quite a extensive collection of images of the arm.
http://www.aca.gr/forum/printview.php?t=1853&start=0
Clearaudio's answer to the Cantus. What's interesting is that the bearings are convex shape.
Opus 3 Cantus parallel tracking armHide this!Advertise here!
The Ikea curtain rail air parallel tracking tonearm! ericpeters Analogue Source 175 22nd March 2014 02:30 PM
My take on TPA's Opus DAC orthoefer Digital Source 9 18th April 2008 01:51 PM
Opus Dei! mikeks Music 6 25th January 2005 10:37 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
