Opus 3 Cantus parallel tracking arm - Page 13 - diyAudio
Old 6th May 2010, 11:26 PM   #121
Nanook is offline Nanook  Canada
Nanook's Avatar
Default overcomplcating a tonearm.
All,
simpler really is better.
DD:, your idea has some merit, but anything that rides above the pivot point(s) is inherently unstable. Hang the mass, don't try to "push it up".
Perhaps there is a solution that is even simpler. Get a piece of Teflon (the real thing). glue to a horizontal bar. Etch or score the Teflon with a horizontal line. Take 2 high precision ball bearings (.1mm or less), and attach them to small vertical shafts which attach to a horizontal "carrier". The horizontal carrier then attaches to a vertical piece, which becomes a location to attach the counterweight and tonearm shaft. The arm then rides on the little ball bearings horizontally while being free to pivot.
stew -"A sane man in an insane world appears insane."
Old 6th May 2010, 11:30 PM   #122
diyAudio Senior Member
fdegrove's Avatar
I think that with air or magnetic arms or tables for that matter you have an unfortunate disconnect and compliance issues which are easily dealt with in a mechanical design but not so otherwise.
I think the main problem with those engineering solutions is that the contact area is just too large, too dispersed.
Basically you'd like to mimic a mechanical diode, i.e. creating a preference path of low mechanical resistance that evacuates vibrations created by the cartridge/tonearm interface and at the same time make it hard for those vibrations to travel back to the source.
I could and have in fact developped this engineering theory on this forum before. I guess the relevant info is tucked deep in the archives by now...
If needed I could rehash this if you guys are interested.
Frank
Old 7th May 2010, 12:05 AM   #123
Directdriver: thanks for the excellent idea. I like the out of the box thinking going on here. Stew is right in that hanging the arm is a better way to go. Your brain has got a train on tonearm designs go man go.
moray james
Old 7th May 2010, 12:10 AM   #124
Frank: are you are referring to the Cantus style bearing assembly or to air /magnetic versions? Moray James.
moray james
Old 7th May 2010, 12:25 AM   #125
Fred: can you post a link or pictures of Tom Fletcher's Radial tracking unipivot arm? I cannot find anything on line. Thanks.
moray james
Old 7th May 2010, 12:32 AM   #126
fdegrove's Avatar
I wasn't refering to any particular design nor any design in particular...
Unfortunately I am not intimately familiar with any of the design approaches of the Opus3/Rauna family of tonearms.
Just pointing to some sound engineering solutions we applied back when we were of a bunch of enthusiastic engineers striving to extract the utmost of what we had way back then.
The odd number of contact points and the mechanical diode principle are ideas you can apply to any tonearm design be that tangential or otherwise.
Later on we suggested the same idea to speaker mounting, speaker to floor interfacing, etc.
Surely you do remember tiptoes, spikes, etc.? Same thing even though tiptoes and spikes aren't if you catch my meaning...
Anyway, should you feel it's redundant or irrelevant news, I'll keep out of this thread. No probs.
Frank
Old 7th May 2010, 01:29 AM   #127
Sheldon is offline Sheldon  United States
Originally Posted by directdriver View Post
Here's another thought in my head. If I use two round rods in parallel on the horizontal plane, I can use two U-groove bearings gliding laterally without any vertical movement. And then I can place a dual-pivot housing with two spikes and an armwand.
I may misunderstand your intent, but it looks like the bearing would roll on one rod and slide on other.
Sheldon
Old 7th May 2010, 01:37 AM   #128
directdriver's Avatar
Nanook: "anything that rides above the pivot point(s) is inherently unstable. Hang the mass, don't try to "push it up".
If I place the spikes below the mid-point plane of the rods, then the mass is hung.
I can't visualize the teflon solution yet perhaps you can draw up something for me? Thank you and always appreciate the suggestions.
Old 7th May 2010, 01:40 AM   #129
Frank: sorry I called you fred my fingers don't always make sound contact with my brain. I am sorry if I gave you the impression that I was not interested in you ideas I am. Yes I follow you regarding the mechanical diode principle. I am not clear what you were referring to when you mentioned "those engineering solutions" in post #122. I think that a hard mechanical contact has distinct advantages over an air or magnetic (floating) bearing. With a non contact bearing there is compliance at some frequency which may cause issues and damping becomes more complex to deal with. I think that you were referring to air and magnetic solutions is that correct? If so then we are on the same page.
Frank are you familiar with the relationship between hardness and friction? I would like to understand what the impact is of making a bearing harder and the affect that has on friction and at what point do you reach diminishing returns. For example the glass tube in a Cantus is about 6.5 on the Mohs scale of hardness and the bearing is probably 25 - 35% harder. Would increasing the tube hardness to say the same hardness as the bearing result in a significant decrease in friction? Is it ideal to make both contacting surfaces equally as hard? Any thoughts would be welcome. Thanks regards Moray James.
moray james
Old 7th May 2010, 01:55 AM   #130
Sheldon: "I may misunderstand your intent, but it looks like the bearing would roll on one rod and slide on other."
You are right! Obviously my idea was not well thought out. D'oh! Thanks for the correction. The only way to make it roll smoothly without vertical movement is to have three bearings to create a triangle carriage for the vertical bearing. But by that point, it might get too complicated and very much simulated the Souther approach. Duh!
Back to the drawing board again!
The Ikea curtain rail air parallel tracking tonearm! ericpeters Analogue Source 175 22nd March 2014 03:30 PM
My take on TPA's Opus DAC orthoefer Digital Source 9 18th April 2008 02:51 PM
Opus Dei! mikeks Music 6 25th January 2005 11:37 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 08:12 PM
Copyright 1999-2017 diyAudio
