Crystal Controlled Turntable Power Supply
Old 10th May 2004, 08:46 AM   #1
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Default Crystal Controlled Turntable Power Supply
I have found by accident and interesting TT product. Maybe this prodcut also can be used in a phase locked loop?
http://www.wnaudio.com/turntablepsu.html
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 47 paid.
Old 10th May 2004, 12:09 PM   #2
Raka is offline Raka  Europe
Raka's Avatar
From the description, is about the same ps I built.
What is beyond the speaker?
Old 12th May 2004, 03:38 PM   #3
earsandeyes is offline earsandeyes  Netherlands
earsandeyes's Avatar
Default is there a thread?
Did you post a thread on this DIY build one?
Old 12th May 2004, 09:22 PM   #4
Raka's Avatar
Search for "change in frequency mains".
Old 24th May 2004, 03:40 PM   #5
carlosfm is offline carlosfm  Portugal
Banned
Default One day...
engineers will (re) discover an old and better technology for the TT, ditching the crappy belts and the noisy motors:
Quartz Locked Loop Direct-Drive.
Old 24th May 2004, 07:17 PM   #6
Raka's Avatar
Carlos Prophet, have you compared your DD to any other belt drive?
Old 25th May 2004, 08:55 AM   #7
Banned
Of course.
The Rega P3 sounds undynamic to me.
And Rega TTs (and many others) use a slightly faster speed than the 33 1/3 to account for the belt getting older.
And that also gives a false sense of detail.
This is shocking to me.
Is there any precision here?
If DD wasn't better, then why would all decent tape decks (including Nakamichi) used them?
They massively reduced wow&flutter using quartz-locked direct-drive motors.
Isn't speed stability important?
People are paying 1k+ Euros for a PSU for their TT to get speed stability anywhere near a good DD TT.
Raka, until the mid-80's some very serious DD TTs were made (yes, much better than mine ), even by today's standards.
But audiophiles like to pay thousands for a crappy belt and an ultra-expensive PSU, motor...
BTW, belts don't last long, you know?
They loose their properties fast.
Precision with a belt?
I said purists will kill me.
But can anyone prove me wrong?
Just put a good DD motor on Linn LP12 and give it a go.
Old 25th May 2004, 09:02 AM   #8
Banned
Spend thousands on a PSU and see if you can get specs like this (my TT).
Also, look at the 10kg weight comparing with the cheap and suspensionless construction of the Regas.
Old 25th May 2004, 09:35 AM   #9
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
Carlos
You may wish to slightly broaden your listening horizons before proclaiming winners. The spec sheet you posted is exactly as meaningless as that of any Pioneer amp from 1974. Which is not to say there is anything inherently wrong with DD. It's just much more difficult to achieve outstanding sound using it.
Some of the most atrocious sounds in my home have come courtesy of the DD crowd darling - the Trio L07. A Dual 701 otoh offers amazingly good sound for the money.
Regarding the PS electronics it's obvious that a DD system is a lot more complex and finicky. It's only market forces which create the >1000 euros synchronous power supplies.
Using a Rega as a belt drive reference? Please give us a break.
Have you ever heard a good idler wheeler?
Old 25th May 2004, 09:43 AM   #10
UrSv is offline UrSv  Sweden
UrSv's Avatar
That heatsink on the back of the PSU looks just like an ILP amplifier module...
UrSv
Those who say it can't be done should not stop those who are doing it.
Crystal Controlled Turntable Power SupplyHide this!Advertise here!
The electronically controlled AEG G 020 motor - is it good for a DIY turntable? waretweaker Analogue Source 10 8th July 2015 10:01 PM
Micro Seiki BL 99V - turntable Power Supply CHEVALLIER Analogue Source 7 13th March 2007 07:19 PM
Turntable Power Supply DIY needed promitheus Analogue Source 14 21st August 2006 12:02 PM
Turntable Power Supply passing thru Analogue Source 3 23rd December 2003 09:59 PM
