| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#101 |
This Shure cartridge has an inductance of 720 mH. 450 pF of shunt capacity is way too high. You will have a big electrical resonant peak around 10kHz. The maximum shunt capacity for the Shure V15 (about 500 mH inductance) is around 120pF so the maximum shunt capacity for this cartridge should be around 100pF.
Regards, Ray |
#102 |
why does the site tell me
"Recommended Load - 47 kilohms in parallel with 450pf" then? I don't understand why they would tell me the wrong thing.
http://www.caraudioconnoisseur.com/ |
#103 |
I don't know why Shure tells people that. If you model the cartridge as a low pass filter with that termination you will find the frequency response has a peak on the high end and the cutoff frequency is well below 20 kHz.
For example, Shure recommended a 250 pF termination for the V-15. It should be about 120 pF for a maximally flat frequency response and for a maximally flat phase response the value should be about 60 pF. That is the total capacity in the cartridge, tonearm wireing, interconnects and preamp. That low a capacity is difficult to obtain. Properly terminating a high inductance cartridge is difficult because they require very low capacitance or you will have a resonant peak in the frequency response and the bandwidth will be less than 20 kHz. Regards, Ray |
#104 |
q: how do you calculate the optimum capacity/impedance for termination of different cartridges?
Si fractum non sit, noli id reficere! |
#105 |
You use the formula Q=R*SQRT(C/L) where SQRT means to take the square root. This is the formula for the resonant Q of a parallel resonant circuit. R is the terminating resistance, typically 47K, L is the cartridge inductance and C is the terminating capacitance. The Q should be between 0.5 and 0.7. A Q of 0.5 gives a maximally flat (no peak) phase response and a Q of 0.7 gives a maximally flat frequency response. At these low values of Q the bandwidth is approximatly the resonant frequency of thegiven by F=1/(2*Pi*SQRT(L*C)).
These formulas are approximations, the mathematically exact formulas for the Q and bandwidth are more complicated. Regards, Ray |
#106 |
#107 |
Here are my eagle PCB files just in case anyone in the future wants to use my design.
#108 |
Very nice pcb design maxw.
Hope it sounds as good as mine. Takes some time to run in. Look forward to your listning tests.
Music is what i want, music is what i need |
#109 |
1. Has anybody tried using silvered mica capacitors for the RIAA feedback loop? These are available in 0.5% tolerance at Farnell.
2. Is the 4.7 uF Blackgate non-polar output cap an arbitrarily chosen value? Only 10uF is available in our place and I'm wondering if this will suffice. |
#110 | |
http://www.acoustic-dimension.com Hope this helps.
| Page generated in 0.10922 seconds (86.12% PHP - 13.88% MySQL) with 11 queries |
