| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I decided to return to the analog fold only to discover that
my grace 707 needs new wires. The female plug in at the end of the wires from the headshell has failed. Is a direct replacement avaliable for a reasonable cost or a good used one if the price is cheap. Thanks, Bob12345678 |
#2 | |
* when i worked in the hifi store we literally sold something like a thousand of these. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Thanks for the feedback. I may just do that.
Regards, bob12345678 |
#4 |
Well I am almost done fixing my Grace plug in wires. I will find a way but is there a tool made to strip that real fine tone arm wire?
Regards bob12345678 |
#5 |
Depending on the insulation, you can frequently just start soldering and the heat will melt the insulation as you go.
Failing that, I always used a sharp knife and steady hands. Another alternative, again depending on the composition of the insulation, is to dip the ends into something like acetone, which will dissolve most plastics very quickly. Grey |
#6 |
I got a nice little tool for Christmas from Allen Wright that won't nick those skinny wires (at least the solid ones);
As a backup i have a pr of ceramic (NASA grade -- made in Finland) front teeth that do a good job. dave
#7 |
How come the image tag sometimes drops a URL in (like above) and not the picture as expected?
dave
#8 |
Hi, One of the internal wires has broken in my Grace 707. I plan to rewire with a single run to the plugs. Can anyone help with information before I start. I am mainly concerned with removing the female DIN plug from inside the pillar.
Thanks, Kevan |
#9 |
Hi
I had a similar problem with channels going and connectors inside the armpost becoming corroded or worn. The nylon? socket inside the armpost is held by either a slotted or allen grubscrew which usually also connects with an earthing plate inside the armpost. There is a bit of wire-slack and you can withdraw the nylon connector if you need to work on it. In extreme cases, I've done this job the hard way, making replacement din sockets for both the armpost (male) and the armlead (female), but you would need a lathe and a milling machine for that. Making one-offs are truly horrible little jobs as great recision is needed for the plugs and sockets to fit correctly. Regarding baring fine arm wires for soldering, I use an NT cutter blade (model A-300). These blades can be snapped-off and I have a collect-type holder for single pieces of these very sharp blades. A very gentle touch is needed in stripping the insulation. Practise makes perfect. bulgin |
#10 |
Thanks Bulgin, I should finally get bifocals before starting.
Would it be better to get the Cardas 4 x 33 shielded and strip back the first foot or buy individual wire and cover the external section with teflon tube and flex? Thanks, Kevan |
| Grace G-707 headshell | Gram | Analogue Source | 14 | 27th July 2008 09:16 AM |
| Grace F9E | Keithj | Analogue Source | 6 | 19th July 2004 11:23 PM |
| Grace 707 | ingvar ahlberg | Analogue Source | 9 | 21st March 2004 11:47 PM |
| WTB Grace 707 tonearm | woody | Swap Meet | 0 | 17th June 2003 12:17 PM |
| Page generated in 0.10428 seconds (78.67% PHP - 21.33% MySQL) with 10 queries |
