Hello,
acrylic (PMME) is really expensive, I got mine quite cheap from Thomas Scheu (www.scheu-analogue.com); you can use hard PVC instead (black would be nive too look at) and should be relatively cheap. But you won't get it that thick, I guess.
If I had to choose from zero I wouzld go for one or two inchjes of solid aluminium and on top of that a layer of same thicknes made out of acrylic or PVC.
On my website there are few thoughts about platter material, I read a few articles recently reviewing Transrotor Turntables whicha re offered with different platters, the differences wherer described exactly. But I can't recall everything now ...
Cheers
Christian.
Cheers
Christian.
krishu
thanks for the info. I was thinking about a sandwich type of thing, and actually I have a sheet of 1/4" UHMW that I could use as the top layer. UHMW is a Static Dissipative so I think that will be a good material, although I will need a way to keep the LP from slipping on its surface, maybe a rubber insert right at the label area and a LP clamp on the spindle. Jury is still out on the second layer but Polypropylene is cheep so I may go there, or ill just use an old aluminum platter from my gerrard lab 80.
Thanks for the help.
Milo
Milo
In general, it isn't. There are static dissipative grades available that contain semiconductive fillers.
If I could choose any material, it would be a highly-filled vinyl (PVC) or a hard rubber (up in the Shore D range), to provide mass loading and a reasonable acoustic match to the record. The price of the material is one thing, but you also have to consider that it will still probably need machining to get it flat and smooth enough.
where do you find out info like that? from a product catalogue? Are there suppliers who will sell small amounts of this type of material, who will also be able to give you this kind of information?
...thanks, I hope no-one minds me butting in...
The following links are pretty useful for info on polymers.
Boedeker Plastics
and the
Polymer Search Engine
Hope this helps
James
Boedeker Plastics
and the
Hope this helps
James
- Analogue Source
- Platter material
