Rotel RIAA Module
Rotel RIAA Module
Old 12th July 2018, 07:54 PM   #11
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Rotel RIAA Module
Quite a few low-offset opamps will allow dc coupling at output. As for the MKS caps beating all lytics i am not convinced at all. Perhaps they will be an improvement over the stock caps.
Old 12th July 2018, 08:15 PM   #12
schillg11 is online now schillg11  Germany
I didn't argue , that they will beat all electrolytics. There will be a sonic improvement against the orginal equipped one and longterm stability will also be improved. A further improvement may be replacing the 1206 resistors with Mini-melf resistors, as suzyj showed in her investigations (better THD).
@ merlin el mago
The lowest voltage available is 50V and the maximum capacity is 10F with pin spacing of 5mm (acc. https://www.wima.de/wp-content/uploa...WIMA_MKS_2.pdf).
Old 12th July 2018, 09:25 PM   #13
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Rotel RIAA Module
Maybe try with Nichicon ES bipolar electrolytics first. In terms of distortion these caps are extremely clean.
Rotel RIAA ModuleHide this!Advertise here!
How to decouple the PSU from amp module in Rotel amp? Buhl Solid State 2 14th June 2017 11:14 AM
LCaudio RIAA module with MC matcc Swap Meet 0 12th May 2014 11:42 AM
WANTED : Rotel Preamp (with Remote) & Rotel Power Amps - Working or NOT dtm1962 Swap Meet 7 18th December 2012 06:45 PM
Designing a Phonostage with the S&B 10K LCR RIAA Module ThorstenL Tubes / Valves 27 9th October 2012 11:13 AM
Rotel RB-1091 For Sale 2x(1000ASP Module) Magasritos Swap Meet 1 12th April 2010 02:58 PM
