Aristotele logical on Vinyl
Old 13th June 2018, 05:54 AM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Aristotele logical on Vinyl
inverting the same signal twice the result does not change
but
the low frequencies are in mono in the stereo system
then
they are complementary on the power supply
also inside equalizer
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 13th June 2018, 10:42 AM   #2
bbftx is offline bbftx  United States
bbftx's Avatar
This idea is indeed almost as old as Aristotle!
It's covered in A.J. van den Hul's FAQ on Phono Cartridges, question #162:
AJ van den Hul Phono Cartridge FAQ
Other forums have discussed this as well. Example from 2009:
AudioKarma Thread on Cartridges Wired OOP
B B
Old 13th June 2018, 11:22 AM   #3
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
IMO if that makes any audible improvement then you have a very suboptimal amplification chain.
Old 13th June 2018, 11:25 AM   #4
lcsaszar is offline lcsaszar  Hungary
Genial idea! If I understand correctly, L pulls and R pushes the power supply at low frequency, this way the combined power is not fluctuating but constant.
But you don't need to tamper with the phono cartridge, this trick (phase inversion in one channel) can be done in the preamplifier.
Old 13th June 2018, 01:37 PM   #5
Stee's Avatar
Default yes of course
easy to do
Old 13th June 2018, 01:40 PM   #6
billshurv's Avatar
And still pointless unless you have a PoS amplifier.
Old 13th June 2018, 03:52 PM   #7
ralphfcooke is offline ralphfcooke  United Kingdom
Not always the case if you are using higher power class D amplifiers with a single power supply, it significantly reduces 'pumping'
Old 13th June 2018, 04:26 PM   #8
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Highly doubtful with any reasonable amplifier design. But it would be easy to measure to test your theory.
Kevin
Old 13th June 2018, 05:13 PM   #9
Sorry, should have read 'Single ended' rather than 'single power supply'.
Have a look here for background data:-
https://www.maximintegrated.com/en/a...ex.mvp/id/4260
Old 13th June 2018, 08:30 PM   #10
MarcelvdG is online now MarcelvdG  Netherlands
That's the one thing I don't like about this forum: whenever someone comes with a clever idea to improve something, there is always someone nagging that it's useless because a stupider solution is good enough.
Aristotele logical on VinylHide this!Advertise here!
I cannot get a logical simulation result on this Alan0354 Software Tools 20 10th February 2015 02:40 PM
What is a Logical Way to Pick Drivers (and matching components)? Frankie Carbone Multi-Way 9 28th October 2012 03:29 AM
Logical Wings LF-38 - are there informations? tiefbassuebertr Subwoofers 3 25th November 2011 07:19 PM
Next logical step in that quest for symetry? Thunau Pass Labs 2 26th February 2004 06:41 PM
too logical theChris Everything Else 1 15th November 2003 02:39 AM
