| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi all,
Some time ago, there was quite an interesting debate on the asylum concerning current sensing phono stages (for MC, that is). http://db.audioasylum.com/cgi/m.pl?forum=tweaks&n=72458 It is mainly an I/V Converter with some (remarkable) tweaks. I understand that some of the protagonists posting here as well. How might such a design rate against some highly regarded actual projects around here? I understood, that the current sensing part is discussed in papers like that (Fig. 2(b)): http://focus.ti.com/lit/an/sboa034/sboa034.pdf Together with the hints Jon Risch gave in the asylum it should'nt be too hard to track things down I happen to have two trashed DL103's with working coils, so a balanced version with frozen assembly would be doable. I would be glad to get some respond, Rüdiger |
#2 |
#3 |
Check out the patent on Dynavector's circuit. A bit vague, but
will give you some info. Some searching of the USPTO web site using their search engine should yield the patent.
bel |
#4 |
#5 |
OK, since you couldn't find it for yourself.
www.uspto.gov the patent is # 4,644,517 I'll leave it to you to print out. The circuit you show has too many moving parts. All that stuff connected to the "+" inputs of the OPA2604's is probably unnecessary. Also, to do the frozen coil thing, it looks like you'll need at least two dead cartridges. I believe tat Risch said you could get by with just having one of them in one "side" of the circuit, but maybe more is merrier.
bel |
#6 | |||
OK, I did not get that the searching machines covered different timeframes... Thanks Quote:
Hm, I'm wondering a bit about the low interest this thread provokes. Do you think, that the current sensing approach is crap? Old stuff not worth trying? Anything Else? Rüdiger |
#7 | |
. Still, the current approach may be different. As this is quite a simple project it's definitely worth building. As a matter of interest what do you use at present? |
#8 |
Recently, I finished (?) my version of the la bohème stage www.klaus-boening.de It sounds great, and it is more the success that encourages me to try something else/further than an actual discontent. I'm open minded to tranformer-based solutions, discrete, valve and so on, but Klaus Böning, or Blue Amp or Horch are proving that one can achieve great results with op-amp based/involved solutions as well. Rüdiger |
#9 | |
#10 |
Some guys at MIT 20 years ago were convinced that this was the final answer in terms of vinyl reproduction. They used discreet npn's and pnp's (I can't give away their circuit even though they never went anywhere with it). They thought that you got mechanical damping on the cantiliver that greatly reduced mistracking, I have no evidence that this is true. For geometry mistracking it obviously can't be true. BTW some of what Mr. Risch said in that asylum thread is wrong, you do not need low current noise for this circuit. The TI/BB app note is about photo diode amplifiers for CAT scanners and is also not particularly relevant and could lead you astray.
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 06:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 10:51 PM |
| reduce before amplifying? | kathodyne | Tubes / Valves | 11 | 8th September 2005 12:44 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 07:41 AM |
| Current amplifying vs. voltage amplifying. | roly94 | Solid State | 14 | 23rd July 2002 10:32 PM |
| Page generated in 0.12385 seconds (79.70% PHP - 20.30% MySQL) with 11 queries |
