| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#71 | ||
diyAudio Senior Member
Not that it would matter for what you're trying to do but still. Quote:
Catridges aren't DACs and vice versa....so I second Analog_sa 100% here. Cheers,
Frank |
#72 | |
#73 |
Just curios to discover if anybody has built any phono from what it has been discussed here?
#74 | |
in my current project (a deviation from rjm's phonoclone), I use the AD811 in the way Scott described here some time ago. I've tried some other chips here, (both cfa and 'normal'), but that one works best. That with -probably Ri-wise- suboptimal DL103. But, I have a strange issue: without tweaking the offset, I have an input offset of around 0.2 - 0.4 mV. It works with the denon cartridge, but i fear it would fry a cart with say Ri=1 Ohm. However, if I tweak the offset to zero as described by Scott, the sound gets dull as if the tweeter is missing. Can that be? Or is this something else going wrong? Rüdiger |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 06:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 10:51 PM |
| reduce before amplifying? | kathodyne | Tubes / Valves | 11 | 8th September 2005 12:44 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 07:41 AM |
| Current amplifying vs. voltage amplifying. | roly94 | Solid State | 14 | 23rd July 2002 10:32 PM |
| Page generated in 0.09761 seconds (72.46% PHP - 27.54% MySQL) with 11 queries |
