Old 25th April 2004, 07:21 AM   #51
Banned
Send a message via Yahoo to Elso Kwak
Thumbs up The Levinson JC-1AC
Originally posted by john curl
The Levinson JC-1AC was developed 29 years ago as an AC version of the JC-1. However, I made a 'fatal' mistake. I used a LOW Z input by using a grounded base connection as the input. This overdamped the MC cartridges. I proved this by rewiring the design to be switchable to either 100 ohms input or grounded base (very low Z) and listened to the difference. 100 ohms input won the contest.
Hello John,
Don't be too modest. The Levinson JC-1AC was the best head amp I could find in that time.
I compared it with numerous head amps from Ortofon, Thorens, Van Den Hul a.o. and even more step up transformers. The JC-1 AC was always the clear winner.
My own JC-1AC was struck by lightning on the electricity grid of the street illumination. Also the cartridge and some modules in the JC-2 were gone. When this happened the model was discontinued so I decided to build my own with the SSM2017.
Old 25th April 2004, 11:50 PM   #52
Elso, it might be that your phono cartridge preferred a summing type input or low Z. The JC-1 AC sounded 'overdamped' with my phono cartridges. I am not criticizing the rest of the design that much, even if I don't use it anymore.
Now, this thread has all sorts of people 'discovering' summing type inputs and while this is OK, it can also be a problem. For example, about 20 years ago, I designed my Vendetta Research SCP-1 (SCP-2 as well) input stage with a link that could be changed to have a summing type input. In future designs I have thought to eliminate this link because it didn't seem necessary for modern moving cartridges. However, JCarr and others have found low Z to be a good load for moving coil cartridges in some models. This is interesting to me, but I do wish that I had a specific model MC, or a design parameter to follow in order to determine what direction to go.
Old 26th April 2004, 02:00 PM   #53
BrianL is offline BrianL  United States
So, John, to clarify what people have not stated clearly:
In the "old days" when the summing junction input (transimpedance
amp) was useful for phono cartridges, the cartridges themselves
had very low impedance and very low output. The advent of
MC's with medium/high outputs (and corresponding higher
output impedances <due to more windings of finer wire?>),
the transimpedance input is not the best match.
(the bottom line being that cartridge designers have been
trying to make their designs easier to interface with "normal"
electronics, improve s/n, etc.)
Is this a correct summary?
If so, it would seem that this would still be useful for cartridges
that are still designed using very low-Z.
bel
Old 26th April 2004, 02:27 PM   #54
diyAudio Senior Member
fdegrove's Avatar
IMO, certainly.
The top quality MCs are still very low output and since these tend to be fitted to the best systems around, the capability of the preamp to convert that tiny signal into a usable voltage is still as important and difficult as ever.
Frank
Old 26th April 2004, 06:37 PM   #55
Actually I don't know what the exact mechansim is, but I was once told that the magnetic assembly is important. Hi Z windings certainly would 'tend' to increase the optimum loading, all else being equal, but many MC's are still low Z and apparently, in one extreme case, best loaded with low Z. Go figure! Where are the phono cartridge designers, now that we need them?
Old 26th April 2004, 06:46 PM   #56
SY's Avatar
I'm telling you guys, give up this magnetic stuff. FM cartridges are the way to go. Where's Paul Weathers now that we need him?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 26th April 2004, 11:54 PM   #57
fdegrove's Avatar
Not from the one you probably had in mind but here's the specs of one of the best I know:
J.A. MC 2 Finish:
Coil impedance 32 Ohm
Load impedance 845 Ohm
Load capacity 150 pF
Stylus pressure 1.8 Grams, (Max Tolerance 0.05 Gram)
Output Voltage 200 µV
Max tracing capacity 400 µmm
Channel separation 70 dB at 100 Hz
60 dB at 1 Khz
70 dB at 20 Khz
Frequency range 3 Hz to 100 Khz
Total THD % 0.1 %
Total unit weight 10 Grams ( incl. socket screws)
Frank
Old 28th April 2004, 10:30 PM   #58
I am sorry that we got no feedback from MC cartridge designers. 845 ohms? Oh sure!
Old 28th April 2004, 10:55 PM   #59
SY's Avatar
Well, John, going to 847 ohms can ruin the soundstage and smear the transient purity. Or something. At 843 ohms, the timing, rhythm, and pace of the music is altered beyond recognition. Or something.
Old 29th April 2004, 12:17 AM   #60
Banned
Default PRAT?????
You need to stop reading the Naim users group forum.
Jocko
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
reduce before amplifying? kathodyne Tubes / Valves 11 8th September 2005 11:44 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Current amplifying vs. voltage amplifying. roly94 Solid State 14 23rd July 2002 09:32 PM
Page generated in 0.12098 seconds (79.66% PHP - 20.34% MySQL) with 11 queries
