| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
Onvinyl:
"if offset is no problem" OPA2604s are FET-input. You really don't need to match the impedances to compensate for bias currents as they are essentially zero. Also, the resistors you need are equal to roughly half the cartridge coil's resistance which is pretty small for the MC cartridges. You're not likely to budge any DC offset by fiddling with pots on the +inputs. Could the low interest in this thread be because most people don't "get it"? I see that there are at least two audiophile/engineers reading and commenting, both of which are involved in high- performance semiconductors as a profession. ----- Scott: That's "BB/TI", not "TI/BB" ! ;-) I agree that the photodiode ap-note is not that relevant
bel |
#12 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#13 |
#14 | |
Brian - If you want a quick try on this, take the lowest _voltage_ noise CFA you can find, use the cartridge resistance as gain resistor and an appropriate resistor as feedback resistance to get the gain. So if you have a cartridge that measures 5 Ohms say use a 500 Ohm feedback resistor. I don't think any offsets get in the way current or voltage (a few microAmps one way or the other flow in the coil). OTOH you might want to select for lowish Vos or tweek it (pot on the rails with a big divider to the +input, for instance).
#15 |
I think this is a rather interesting topic. What happens if you take out the current from the pickup with no voltage across it (= zero Ohms inimpedance) compared to "measuring" the voltage (=high inimpedance) and take out no current?
#16 | |
For my MC15 inductance is not given but I believe its 50uH to 100uH. Lets assume 100uH (50uH) with specified DCR of 6R. F3 = 9.6KHz. (19KHz) Which ties in with recommended loading of > 20R. F3 = > 40kHz. (80Khz) sreten.
#17 |
You really don't want to use a FET input op-amp in this application. As a broad generalisation, FET op-amps are dominated by voltage noise, whereas bipolars are dominated by current noise. When you use a moving coil cartridge as the source, its low source resistance means that the current noise hardly develops any voltage, meaning that bipolars are quieter. AD797 might be a good choice.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#18 | |
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#19 | |
#20 |
As said, not much happens: the record plays, the music flows ...
I tried Scott's suggestion years ago with AD811 or LM6181, using an Ortofon MC25FL. Worked rather nicely, but I abandoned the scheme because I desire more flexibility/compatibility from an MC-preamp. And anyway, I changed over to a medium-Z medium-output cartridge shortly after. |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 06:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 10:51 PM |
| reduce before amplifying? | kathodyne | Tubes / Valves | 11 | 8th September 2005 12:44 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 07:41 AM |
| Current amplifying vs. voltage amplifying. | roly94 | Solid State | 14 | 23rd July 2002 10:32 PM |
| Page generated in 0.12964 seconds (78.33% PHP - 21.67% MySQL) with 11 queries |
