Drive the input and look at the right and left outputs. No pilot or subcarrier required.
Response for 50us should be -3dB around 3183Hz. (use 100Hz for the reference frequency, measure between 3150 - 3200Hz and you'll be close enough)
More here: FM Pre-Emphasis and De-Emphasis
Thanks a lott, I'll reed all of this prior to check and adjust.Drive the input and look at the right and left outputs. No pilot or subcarrier required.
