Old 11th April 2004, 03:11 PM   #1
Send a message via ICQ to patientdog Send a message via Yahoo to patientdog
Default SME 3012 circa 1969 cueing mechanism
I have one of these with an Ortofon SPU Gold [Van den Hul retipped]
The silicon damping fluid in the cue mechanism has dried up which means that I dare not let the arm auto descend - unless I want to watch the arm bounce up and down on the record until the cantilever breaks.
Has anyone ever replaced the fluid in the cueing mechanism?
It used to be a factory job but SME no longer services the 3009 etc range so I have been told.
I supect you can't actually open the shell to replenish the damping fluid.
Old 11th April 2004, 09:39 PM   #2
ingvar ahlberg's Avatar
Hi
As far as i remember the vertical "pin" in the lift is threaded so You can unscrew it and get new fluid in. But i think You would get the field sevice manual from:mailto:service@sme.ltd.uk (The SPU and 3012 combination i think still is about as good as it gets )
Ingvar
Old 11th April 2004, 10:32 PM   #3
analog_sa's Avatar
I've done it a few times. Don't remember many details other than it was really hard to open it and you need the highest possible viscosity (1000000?) silicone oil. I never managed to get such thick oil but after the repair it worked like a dream anyway.
Old 11th April 2004, 11:50 PM   #4
diyAudio Senior Member
fdegrove's Avatar
Neither have I but I used the thickest grade I could order from the pharmacy and that worked just as well.
If it's the same grade as the one used in the damping trough of the arm itself then I still have an original container from SME in case anyone's desperate...
Frank
Old 12th April 2004, 04:59 PM   #5
Thanks for all this - I will ring SME tomorrow and let you know. Needless to say the pin seemed reluctant to unscrew!
Old 23rd April 2004, 08:38 AM   #6
I did this some years ago with my old 3009 SME. I used 1000000 silicon oil, but 500000 is also ok. You have to dismantle the lever mechanismus by screwing out the 2 little screws on the topside of the lever and putting up the cover and fill in a tiny quantity of such oil. it works fine then
regards
hsort
hsort
Old 23rd April 2004, 05:14 PM   #7
Thanks very much for this - I will have a go.
SME did not want to know - they no longer service these arms.
I did try to buy an old 3009 Series 2 original for the part but was warned that it had the same problem.
Pioneer cs 77 speaker c., 1969 bobhowell Multi-Way 3 3rd July 2009 04:07 PM
Rega arm cueing mechanism problem KKG Analogue Source 6 25th March 2009 07:24 AM
A cueing mechanism to buy/DIY theskintman Analogue Source 1 30th June 2008 12:47 PM
Cueing mechanism BluesMagoos Analogue Source 0 1st May 2007 07:17 PM
1969 Beetle with 35 Amp Generator mi1stormilst Car Audio 5 17th March 2006 10:49 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
