Measuring phono stage RIAA accuracy with a computer
Old 4th April 2018, 10:00 PM   #191
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Originally Posted by MarcelvdG View Post
Getting back to measuring phono stage accuracy, does anyone know a way to measure the response of the cartridge and amplifier together other than simply playing a test record and hoping it was recorded accurately?
I don't see a definitive way without including the vinyl/stylus interface. B&K used a precision accelerometer in reverse as a stimulus, but I don't remember the details.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 4th April 2018, 10:29 PM   #192
Pano is offline Pano  United States
Pano's Avatar
Didn't SY once run the test signal thru the cart? Not sure if that would make a useful difference.
Take the Speaker Voltage Test!
Old 4th April 2018, 10:48 PM   #193
I've done that too but it leaves out all the mechanical effects.
Old 4th April 2018, 11:36 PM   #194
Conrad Hoffman is offline Conrad Hoffman  United States
Never got around to trying it, but I'd think any small piezoelectric disc would be a good exciter for a cartridge, especially if you glued a small piece of a record to it, so the stylus was in a groove. A small disk can have a self resonant frequency in the hundreds of kHz or higher.
I may be barking up the wrong tree, but at least I'm barking!
Old 5th April 2018, 02:15 PM   #195
When I tried them the response was not too flat. There are precision piezo-positioners (some <$40) with self resonances as high as 250k. Piezoelectric Actuators - Thorlabs
Looking over the specs they might be impossible to use at 20kHz since the capacitances are huge. The app notes might ave some good ideas for linearizing cheap disks.
Old 6th April 2018, 05:59 PM   #196
stocktrader200 is offline stocktrader200  Canada
MarcelvdG, I am going to try a cheap in ear headphone speaker glued to a piece of aluminum then place the needle on it with the turntable unplugged. measure the results driving the speaker from an iphone signal generator.
I will see if it requires an RIAA eq. network between the iphone and 32 ohm speaker.
if the cone holds .5 to 1.5 grams it should work
Old 7th April 2018, 10:38 AM   #197
davidsrsb is offline davidsrsb  Malaysia
...Looking over the specs they might be impossible to use at 20kHz since the capacitances are huge...
Looking at the smallest 2AB part with 9nF, ie Z=884, this shouldn't be too hard.
The displacement has hysteresis, which means there are some large distortions to be accounted for
Measuring phono stage RIAA accuracy with a computerHide this!Advertise here!
Phono preamp RIAA curve accuracy easphyx Tubes / Valves 25 10th August 2017 04:04 PM
measuring RIAA filter accuracy robmil Solid State 0 14th September 2008 08:39 PM
WTB: RIAA Phono Stage mrdon Swap Meet 1 19th July 2007 04:00 AM
RIAA phono stage KevinTams Tubes / Valves 10 16th May 2005 01:05 PM
VSE riaa equalizer phono stage Hesky Tubes / Valves 16 28th October 2004 07:50 AM
