Phono switching with relays.
Old 13th February 2018, 01:17 PM   #61
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
Teledynes are a bit out my budget. Shame as they certainly look the business.
Old 13th February 2018, 01:39 PM   #62
Monte McGuire is offline Monte McGuire
Originally Posted by Hans Polak View Post
Thanks Monte for your contribution.
However the Teledyne 712 being a very nice sealed relay, is no longer in production.
For a new design not a good starting point.
Hans
Sad to hear, but thanks for the heads up! There is still stock at some distributors, but at ~$35 per relay, I don't think I'll stock up. There maybe other suitable or equivalent relays, and there are also a wide range of very inexpensive non-hermetic relays for about 10x less cost, such as those from Matsushita and Aromat.
At any rate, thanks again!
Old 27th February 2018, 06:35 PM   #63
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
Have you considered using something like an arduino to get remote capability and oled screen readout?
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Old 27th February 2018, 07:22 PM   #64
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Something like this?
Old 28th February 2018, 04:17 PM   #65
Exactly like that.
Old 28th February 2018, 04:19 PM   #66
What Teledyne 712 model would be most suitable for this application? There’s a variety of them.
Old 28th February 2018, 04:38 PM   #67
billshurv's Avatar
No. I'm already nearly 3 years behind on some projects and this would add another n months. Given that, if I am changing source I will be standing at the turntable knobs hold no horror for me. Plus I want to use the chassis (and holes) I have lying around.
Old 28th February 2018, 04:56 PM   #68
BrianL is offline BrianL  United States
Back to my post #4, look at the Panasonic TX-S with the -1 p/n suffix if you want a good low-signal-level relay at an affordable price. Given your signal levels, reed relays with appropriate contact plating are an option and should not suffer from distortion due to the magnetic materials.
Working 15+ years in two companies that used LOTs of relays in test hardware, one in T&M products and the other for internal Test hardware, I can tell you that both experienced reliability issues with:
- Teledyne -- high priced and high failure rate / short lifespan
- Pickering reeds -- consistently less longevity than other brands
- Coto -- very good supplier, but seriously lost their recipes when they moved the factory to Mexico. Largely resolved but would avoid tiny and expensive form-C model
- Panasonic -- recipe was lost during the change from Aromat->NAIS->Panasonic. This was in the early 2000's and is now history. The existence of the Panasonic TX-S with -1 is a result of those issues.
- other brands, now forgotten (or gone) -- even worse experiences.
Bottom line: No one has been perfect. Given your need for just a few relays, maybe you'll never see a reliability issue no matter who you pick as long as you make a suitable choice.
Bill, while I understand your goals, I question whether you will ever use all the flexibility you're trying to design in. Over the years I've had many schemes and plans for ultimate flexibility -- relay matrices, patch panels to connect anything to anything else, etc. If they were implemented, I found I never did much, if any, rerouting. If not implemented it was because other life priorities prevented the work; usually I ended up throwing a simple ad hoc solution together that was used for years.
bel
Old 28th February 2018, 09:22 PM   #69
billshurv's Avatar
Hi Brian,
You may be right, and I have had several rounds of angst. The current plan is the minimal set of switching I need to support the next few years, and I admit even some of that might be backed out. I had foar more complex plans originally.
BUT I need to implement something slightly less add hoc than I currently use on orders of Memsahib*. And with this plan I can implement it a bit at a time and manage domestic harmony
*As we all know the problem with projects is that the metalwork can be >50% of the cost of the project, esp if you get fancy front panels done with silly things like labels on. It would be good if I could get things to the state where my wife would feel comfortable using the hifi
Phono switching with relays.Hide this!Advertise here!
Muse M20 EX2 TA2020 amp, relays switching on/off Marc G Class D 1 26th November 2017 08:10 PM
Fast/high freq switching audio relays rb46uk Parts 1 8th February 2015 01:33 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
Relays for switching i2s or other 3-wire audio bus? mbcouple Digital Source 19 23rd July 2005 08:58 AM
BOSOZ source switching with SE relays Gabrielshorn Pass Labs 2 5th February 2004 08:07 AM
