Phono switching with relays.
Old 8th February 2018, 09:34 AM   #41
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
Default Phono switching with relays.
In my mind it is completely absurd bordering criminal that a switching device does not exist which can handle multiple (letís say anything more than 2) TTs, any input either stepped up for MC or pass through for mm and even *gasp* handle both C and R loading.
Thereís about 5 gazillion tonearms, TTs and cartridges out there. One would think some people have more than one of each and want some degree of versatility for fiddling?
Every time I see this topic come up it usually gets shut down with a variety of canned reasons from ďyou donít need that reallyĒ to ďbeginners mistakeĒ to ďitís too preciously low of a signal to mess with like thatĒ
Surely the great minds here could surmount the technical obstacles without audible degradation? Iíd even trade some minor degradation for less battling the sea of wires tucked behind my credenza.
Personally I think it could be a giant conspiracy against us Bill, but thatís just me ;-)
Either way Iíll be following with interest.
Only ones Iím aware of currently are the boxes by David Hadaway of dB systems... spartan looking to say the least and itís a multi-box affair. The switches donít use relays- all rotary.
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Old 8th February 2018, 12:49 PM   #42
InSides is offline InSides
Originally Posted by spaceistheplace View Post
In my mind it is completely absurd bordering criminal that a switching device does not exist which can handle multiple (let’s say anything more than 2) TTs, any input either stepped up for MC or pass through for mm and even *gasp* handle both C and R loading.
Perhaps there is not a large enough market for a standalone device?
The Devialet amplifiers (well, their Expert series) allow for switching on-the-fly assignment of inputs and remote selection of, at the very least (1) amplification level, (2) C loading, (3) R loading and (4) compensation curve.
During play, from the remote.
So it is possible, and it does not degrade the sound, not to these ears.
Old 8th February 2018, 10:06 PM   #43
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Space: I'm guilty in the past of relay angst and using rotary switches. I am trying a different direction this time partly because I'm fed up with the wiring rats nest rotaries cause and the fact that some things you just can't easily do with switches.
The whole assembly and ADC is going to end up in the attached. The existing board is beyond redemption. Just not a good design, but the box is good and has WAF. If I lose the balance function I have just enough controls without drilling more holes in the front panel. BUT Can only be done with relays or equivalent and maintain my sanity .
Old 9th February 2018, 03:41 AM   #44
Hiten is offline Hiten  India
Since at a time you will be using only one phono preamplifier, you can use three way on off power switch. This way only one preamplifier is ON at anytime. Will that work ?
Old 10th February 2018, 08:25 PM   #45
PRR is offline PRR  United States
PRR's Avatar
Those big power switches are for POWER. The contact alloy will tarnish, but 240V 20A will blow-through the tarnish. They would not be first-choice for small audio.
However you can get them exceptionally low-price through Amazon, eBay, and direct from Asian web-shops, so would cost little to try.
Old 11th February 2018, 12:26 AM   #46
kevinkr's Avatar
Originally Posted by udok View Post
Read relays have magnetic contacts - lot of distortion and no go for audio
B.S. Are you just quoting internet wisdom or have you measured it? I've designed audio test instruments for semiconductor ATE and was never able to measure any distortion attributable to the Pickering reed relays I used. The measurement system SFDR while not state of the art was better than -100dBFS.
There are many relays and switches that are not suitable for switching low level audio, IMLE reed relays are amongst the most suitable choices with long lived hermetically sealed contacts of the appropriate metallurgical qualities for the task. You of course have to purchase the correct one.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 11th February 2018, 08:49 AM   #47
Hans Polak is offline Hans Polak  Netherlands
Magnetic contacts, lots of distortion, what else have we missed.
I wonder that a small Relay can be criticized to such a degree.
What about the contacts on the Cart itself, neighbouring to very strong magnets.
And what about all the Cinch or Din connectors in the line.
The whole matter is grossly overestimated, and every gold-plated miniature relay or the somewhat larger reed relay can do a perfect job.
Hans
Old 11th February 2018, 05:55 PM   #48
Calvin is offline Calvin  Germany
Calvin's Avatar
Old 12th February 2018, 03:17 AM   #49
Indeed it was for power switch. I was thinking more in the line as below....
Both turntable and both phono preamplifier will be connected to amplifier. (Kind of parallel signal out from both preamp to single amplifier) However the preamplifiers will obviously have two power supplies and with the switch I mentioned will only have option to turn on any SINGLE phono preamplifier. No chance of turning both, so other switched off preamplifier will not be sending any signal to MAIN amplifier. This way one has solid connections of Interconnect cables. Will that work ?
Old 12th February 2018, 08:45 AM   #50
billshurv's Avatar
Generally not good practice to have unpowered circuits hanging in parallel with powered ones. I would not consider that as an option. Once you have gone through the phono pre you will be in the 0.5v range so any relay will do the job fine. Before as several people have mentioned, it's a case of picking the right relay.
Phono switching with relays.Hide this!Advertise here!
Muse M20 EX2 TA2020 amp, relays switching on/off Marc G Class D 1 26th November 2017 08:10 PM
Fast/high freq switching audio relays rb46uk Parts 1 8th February 2015 01:33 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
Relays for switching i2s or other 3-wire audio bus? mbcouple Digital Source 19 23rd July 2005 08:58 AM
BOSOZ source switching with SE relays Gabrielshorn Pass Labs 2 5th February 2004 08:07 AM
