Phono switching with relays.
Old 2nd February 2018, 09:02 PM   #21
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Blimey googling 'Meder Dil5k002 -BV338' returns no results. Not had that in a while!
Old 4th February 2018, 04:31 PM   #22
Hans Polak is online now Hans Polak  Netherlands
Bill,
Switching has to be done with great care to prevent loud clicks in your speakers or even potentially damaging Carts or Preamps.
Preamp inputs have to be short circuited before switching the input lines.
However when using an Aurak type of configuration, when inputs are short circuited, gain and thus noise will massively increase.
That is why you should also circuit the outputs of your preamps before switching.
Leave enough time for settling the relay contacts.
Procedure should be like:
1) Short circuit the outputs,
2) after 5 msec short circuit the inputs,
3) after 10 msec switch the input lines,
4) after 15 msec release the input short circuit,
5) after 20 msec release the output short circuit.
Most miniature DPDT relays with gold plated contacts will do the job like the IM relay series from TE Connectivity.
Hans
Old 4th February 2018, 05:48 PM   #23
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
When i try " dil 5k002 bv338" there are a lot of hits here in europe on google and ebay.
And Hans your right about swiching sounds in low signal circuits. Look at my schematic(post 14), that is why i have also a relais switch at the output of the phonopreamp.
Old 4th February 2018, 06:01 PM   #24
kevinkr's Avatar
Strange because I too am getting plenty of hits and Meder is mentioned in several of them:
2 Stuck MEDER DIL-5K002-BV338, 5V Metall-Relais (M3881) | eBay
Non English listings of course. I would probably go for eBay, but I wonder if there are enough to meet your needs.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 4th February 2018, 09:51 PM   #25
billshurv's Avatar
I know, odd. Google is usually so desperate to return something!
Hans: Good advice. I have done a first pass on looking at the issues around switching inputs and what is needed. I have 3 points where I can and probably do need to mute and the added possibility of powering off whichever phono stage is not in use.
For safety I should consider having a 2 second auto mute on input change, but I view that as phase 2.
Old 4th February 2018, 09:54 PM   #26
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Mmm, "something" being the operative word. Apparently Google isn't very helpful and maybe why some people end up here with their Yet another basic question
PS, I got exactly the same result as you
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 4th February 2018, 10:45 PM   #27
billshurv's Avatar
Well I looked at your thread and I disagree. If you look back there have always been a number of basic questions. What has changed is a higher number of 'what is best x' threads, which never end well .
Old 7th February 2018, 03:50 AM   #28
rsavas is offline rsavas  Canada
Is live signal switching a requirement? If so then you need the elaborate switch scheme, logic control
Another option is to have a separate phono preamp for each TT and do the switching at a higher level. They are not very expensive to build :-) ( The lsk489/LM4562 app is a good one) Go smt to save space.
most phono pre amps have a MC flat gain stage before the MM gain stage with the RIAA and rumble filter if used. Jumpers/switches are used to select MM/MC cart.
Old 7th February 2018, 08:43 AM   #29
billshurv's Avatar
The problem is not one preamp per TT its one preamp per cartridge type and the fact that I now have the possibility to swap arm wands on one of my turntables. Whilst it's unlikely I will be running MM/MC in the same session, if I am testing things I might well do. I could just stick a patch box in between the turntables but being able to just select TT then flick a switch for MM or MC would be a preferable user experience.
And yes the fact that I refuse to follow the norm of an MM stage with headamp before it for MC makes it difficult, but that's the way I want it to be
Old 7th February 2018, 10:52 AM   #30
udok is offline udok  Austria
Read relays have magnetic contacts - lot of distortion and no go for audio
Phono switching with relays.Hide this!Advertise here!
Muse M20 EX2 TA2020 amp, relays switching on/off Marc G Class D 1 26th November 2017 08:10 PM
Fast/high freq switching audio relays rb46uk Parts 1 8th February 2015 01:33 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
Relays for switching i2s or other 3-wire audio bus? mbcouple Digital Source 19 23rd July 2005 08:58 AM
BOSOZ source switching with SE relays Gabrielshorn Pass Labs 2 5th February 2004 08:07 AM
