Phono switching with relays.
Old 1st February 2018, 12:10 PM   #11
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Get a 3rd TT :-)!
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 1st February 2018, 12:26 PM   #12
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
How would that help?
Old 1st February 2018, 07:40 PM   #13
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Somehow I fail to see why sealed, gold contact relays would be any worse the switches, - without checking the realities, capacitance may be an issue for MMS.... OTOH- separate RIAAs would certainly be the better option...
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 1st February 2018, 08:59 PM   #14
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
I use a lot of relays for my phono amp, 3 inputs, mc or mm amplication and loading all switchable with relays. No problems with signal lost.
Old 1st February 2018, 09:34 PM   #15
billshurv's Avatar
I remember Mooly mentioning a few weeks back that most switches were not really fit for the purpose either, but at least you get some wiping action with a switch. In my case doing what I want with switches would be a pain.
Capacitance is not as issue for the MM stage as I'm using a form of trans amp.
Old 1st February 2018, 10:18 PM   #16
kevinkr's Avatar
Originally Posted by billshurv View Post
Any advantage in the wet contact? I see Pickering make it hard to buy, hopefully they will deal with the great unwashed directly.
No capacitors in the signal path, balanced and servo'd all the way. Horrible 8-legs abound . I think I have mission creep down to a point where I can build it in non-glacial time!
Sealed reeds are pretty good without wetting. I used Pickering Form A types in ATE hardware doing audio measurements at very low levels and had no problems.
Hopefully the relays offered are suitable. The Pickering stuff is very good as long as you design to avoid welding. (This is true of all reeds, no indictment of Pickering intended) No input capacitors goes a long way towards that goal.They will never degrade and will operate forever in this application. I got service lives of >2 x 1e6 contact closures without failure during test.
Relays are great if you get the right ones because they generally offer better isolation than the typical low level dpst or dpdt and won't require Bill to run wires all over the place with extremely low signal levels. Also allows for control by a mpu if desired. I use CMOS switches in amplifier circuits designed for measurements but I have not really disabused myself of the notion that they don't belong in audio designs (they probably do).
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 2nd February 2018, 12:00 AM   #17
BrianL is offline BrianL  United States
While I would shy away from Pickering in a production product as I haven't experienced the best reliability with them, Pickering does have the advantage of having options for the contact plating. IIRC, Ruthenium is their recommendation for low-level signals.
However, see the article on reed relay distortion by Samuel Groner and Bruno Putzeys in the last issue of Linear Audio. Fortunately for your application, I think signal levels are low enough that this wouldn't be an issue.
bel
Old 2nd February 2018, 12:16 AM   #18
billshurv's Avatar
As I'd be lucky to be under 3% THD before the signal even reaches the relay. Looking at the published diagram anything under 3mA won't be an issue and you can't get that from a cartridge!
Old 2nd February 2018, 05:42 AM   #19
kevinkr's Avatar
Odd, we used thousands of them in semiconductor ATE test hardware and had very few problems unless we destroyed them by running them beyond the recommended operating conditions. Over extended periods of time in the lab we had less than 0.25% failure rate with lots of mistakes and abuse going on.
I will admit they are very unforgiving if you put significant current through them when the contacts are opening or closing.. (Welded contacts)
Old 2nd February 2018, 06:07 PM   #20
Koifarm's Avatar
I use Meder Dil5k002 -BV338 5v, cheap and good.
Phono switching with relays.Hide this!Advertise here!
Muse M20 EX2 TA2020 amp, relays switching on/off Marc G Class D 1 26th November 2017 08:10 PM
Fast/high freq switching audio relays rb46uk Parts 1 8th February 2015 01:33 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
Relays for switching i2s or other 3-wire audio bus? mbcouple Digital Source 19 23rd July 2005 08:58 AM
BOSOZ source switching with SE relays Gabrielshorn Pass Labs 2 5th February 2004 08:07 AM
