How does turntable AC speed controller work?
Old 17th January 2018, 06:48 PM   #11
Pyramid is offline Pyramid  United States
Pyramid's Avatar
If the drive signal is steady, but the platter speed fluctuates, it may be indicative of other problems with the table such as bearing lubrication, belt contamination, worn belt, slippage etc. Changing to a different controller would not make much difference in this case.
Old 17th January 2018, 07:17 PM   #12
Sunsun22 is offline Sunsun22  Hong Kong
Sunsun22's Avatar
Yes, you are right. I just noticed two out of six belts are worn. Will change them and see if it improves. Indeed, they have been running since 2010. Time to change.
Old 18th January 2018, 01:20 AM   #13
Sunsun22's Avatar
One thing about my controller is it uses a 10K VR to trim the speed that it is difficult to trim. Is there something ready made in the market like a digital trimmer to replace the 10K VR in the circuit?
Old 18th January 2018, 01:40 AM   #14
stocktrader200 is offline stocktrader200  Canada
you can get a 10 turn pot or you can measure the resistance from wiper to end and fit in 1% resistors.
Old 18th January 2018, 03:46 AM   #15
Sunsun22's Avatar
The VR is a dual gangs.
I eventually discovered that the VR is only used as a resistor rather than a divider therefore I parallel a resistor on each gang to lower the total resistance. It is getting easier to fine tune the speed now.
How does turntable AC speed controller work?Hide this!Advertise here!
Fixing speed controller on a Technics SL-BD22D turntable 68Spider Analogue Source 5 25th March 2015 11:10 AM
WTB: Speed controller for Lenco 70 turntable. Thanks. tubeyou Swap Meet 0 27th May 2014 07:22 PM
2 Speed Fan Controller smartx21 Solid State 30 9th May 2013 03:37 AM
DC motor speed controller Matt Rowland Analogue Source 144 28th March 2006 06:39 AM
200 amp speed controller Hayden Analogue Source 6 27th January 2006 11:41 AM
