Trying to repair an old tvv47 phono preamp
Old 11th December 2017, 04:12 PM   #21
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
You didn't understand me. Or didn't want to. I suggested doing my mods after having successfully solved the original issue.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 3rd January 2018, 07:23 AM   #22
onokun is offline onokun  Russian Federation
Long story short, the preamp is now working perfectly.
I've replaced the power xformer, moved it to a separate small box along with rectifier diodes, added a fuse, a "power on" led, and a switch.
For the diode bridge protection I opted for an NTC resistor, hope that this will be enough.
The DC voltages of the preamp are spot on.
Thank you for all your suggestions, they are really helpful )
Old 3rd January 2018, 07:35 AM   #23
Mooly's Avatar
Pleased to hear you found a solution An NTC is OK for protection as long as the transformer is rated high enough to supply the continuous fault current needed to 'trip' the NTC and then to sustain that current.
Trying to repair an old tvv47 phono preampHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Tube phono amp repair/redesign help wanted dikarner Tubes / Valves 67 4th August 2008 06:33 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
