The Rod Elliot Pre Amp First Power Up
Old 10th November 2017, 04:20 PM   #11
traderbam is offline traderbam  Europe
traderbam's Avatar
Originally Posted by DiyGazza View Post
I left the Tone controls exactly as they were for the CD, Dropped the arm sat back and..... "BAM" ..... Was instantly transported back to that sound I never thought I would hear again, It was like the system was on steroids, Tight Punchy Bass, smooth but crisp and clear treble, a really impressive sound stage, very open, I don't think I've ever heard the B&W Speakers sound so good, given that they only use a 6" Woofer / Mid unit, I have to say I was completely and pleasantly surprised at what I was hearing, Now all I need to do is to get the CD's to sound the same which will probably only require a little tweaking and I'll be one happy Chappie.
Good stuff...nice to know your system is making music again.
Any idea about the CD player issue? Do you suspect a circuit problem or the player itself?
Everything matters.
Old 10th November 2017, 10:14 PM   #12
DiyGazza is offline DiyGazza  United Kingdom
Well, actually some slight tweaking of the bass and treble, together with repositioning of the speakers has really improved things, the problem was The pre amp and amp are near the speakers, but some distance away from the listening position, so any adjustments made sounded totally different when sat down, it was a bit of a back and forth to do, but eventually with slight changes each time it reached a point where I thought, Yep, I can totally live with this, So all's good at the moment.
Don't know if you have read the thread I started regarding the Rega Anti Skate Belt?
I've got the arm off and am in the process of making a jig to hold the arm in position while I work on it, I've been taking some pictures as I go, so if it all works out and I don't wreck the arm in the process I'll post them up so any other members who have the same problem Can follow up on the idea and maybe even improve on it, It's no work of art, but if it does the job that's good enough for me.
The Rod Elliot Pre Amp First Power UpHide this!Advertise here!
Trace Elliot AH300-7 power issues Help p7rak Instruments and Amps 1 24th October 2012 07:26 PM
Trace Elliot BOCHIN Solid State 12 13th August 2012 03:05 PM
Problems with Rod Elliot's Project 05 (power supply) lordvader Solid State 3 22nd April 2003 12:41 PM
Increasing power output of Rod Elliot amp mjd_tech Solid State 1 2nd April 2002 09:29 PM
