Test LP group buy
Test LP group buy
Old 11th October 2017, 03:23 PM   #21
Dave Cawley is offline Dave Cawley  United Kingdom
Dave Cawley's Avatar
Would this be as good as the original DIN ones or similar to the Clearaudio ones ?
Dave
"if it measures well & sounds good, it is good" : "if it measures badly & sounds bad it is bad" : "if it measures badly & sounds good, it could be improved" : "if it measures well but sounds bad it is bad"
Old 11th October 2017, 03:36 PM   #22
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by Pano View Post
For the speed polar plot, right?
Yes
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 11th October 2017, 03:41 PM   #23
Originally Posted by anatech View Post
Isn't the standard frequency for speed and W&F test 3 KHz?
-Chris
If you check 3150 is a perfect integer common denominator at 33 1/3 rpm. There are some easily overlooked issues with interleaving the tracks with respect to both rotational and radial velocity.
Old 11th October 2017, 04:10 PM   #24
davidsrsb is offline davidsrsb  Malaysia
Originally Posted by scott wurcer View Post
If you check 3150 is a perfect integer common denominator at 33 1/3 rpm...
I was wondering why my test record used that one.
How about a noise track or sweep with a linear frequency response before RIAA equalisation, to allow direct cartridge measurement without equalisation errors?
Old 11th October 2017, 04:24 PM   #25
Pano is offline Pano  United States
Pano's Avatar
Test LP group buy
I was also wondering about equalized vs not, but that should be discussed with the mastering house. Since they are the ones normally applying the equalization, they would know how easy it is for them to leave it out.
We (Scott) could apply a perfect RIAA curve to the files before they are sent to mastering, but would that mess up their signal flow?
Take the Speaker Voltage Test!
Old 11th October 2017, 04:39 PM   #26
kevinkr's Avatar
Test LP group buy
Not sure about that, most cutting heads do not have flat frequency response and use EQ in addition to the RIAA cutting EQ to flatten out their frequency response or more correctly perhaps bring the overall system response into conformance with the RIAA cutting requirements. More likely you would want a mastering house that could tell you what their conformance to the standard actually is, and select on that basis.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 11th October 2017, 04:55 PM   #27
Yes, there would be value in asking for the RIAA to be turned off and providing an exact RIAA digitally. I know there are things that have to be corrected in the mastering lathe but I still think in lower audio BW's this is a better solution.
As for high frequencies the STR120 claims 50kHz response and it's a legacy test LP. They must be able to do this now.
Old 11th October 2017, 06:20 PM   #28
Pano's Avatar
Test LP group buy
Indeed. Does the cutting master apply RIAA and cutter head EQ separately, or are they bundled together? Another question for the mastering house.
Old 11th October 2017, 07:15 PM   #29
cbdb is offline cbdb  Canada
May as well put square wave and impulses on the record. You'll have 20 minutes. You could even repeats everything at -20db or other level to check dynamics.
Old 11th October 2017, 08:51 PM   #30
Pano's Avatar
Test LP group buy
Or 15 minutes if we keep a nice, wide groove spacing.
Test LP group buyHide this!Advertise here!
Ultimate listening test ... test your ears and audio chain PMA Everything Else 378 21st November 2013 10:20 AM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 09:22 AM
AKSA versus modified unit, a group hearing test inside my appartment destroyer X Solid State 37 4th October 2004 09:18 PM
