Test LP group buy
Test LP group buy
Old 10th October 2017, 08:14 PM   #11
fasterbyelan is offline fasterbyelan  United Kingdom
fasterbyelan's Avatar
Test LP group buy
Originally Posted by Pano View Post
Maybe a DIY test LP is a keen idea. Worthy of its own thread, of course. If we can discreetly get other audio forums interested there should be enough demand to make the price reasonable.
My own thoughts exactly, l would be happy to promote the Test LP on the Lenco Heaven Forum as I have been quite active there.
I think most of us have at least 1 test lp so the one we hope to produce need not repeat phase checks, tracking torture tests ect ect. Something very well made is essential (with an accurate spindle hole position!) My own initial thoughts on the tracks would be -
3150 Hz test tone for speed testing and cartridge setting up
Pink and White Noise tracks, the latter to overcome the -10db per decade decrease in energy of the former.
20 - 20Khz Sweep x 2, one with equal energy per octave, one with equal energy per hz.
Silent Track
Those better qualified than me will tell me if the above are possible but my thoughts are for a test lp that can be used for testing cartridge output and frequency response as well as TT and arm performance. Whether there is any benefit to be had from using 45rpm as the LP's speed, again others can comment. (1 side 33 rpm, the second 45 rpm?)
Karl
Lenco - cause it's got soul!
Old 10th October 2017, 08:42 PM   #12
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
All tracks could be generated by computer and verified and exact digital versions could be available as a download. There also should be a pre-discussion of things that were not possible in the past like setting exact crest factors on the noise bands or the possibility of including complex multi-tone signals. Though I suspect the fidelity of anything unusual will disappoint.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 10th October 2017, 10:42 PM   #13
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
Test LP group buy
One nice thing about an open source test LP is that we could publish the original signal files, as well as the mastered files - if that's a help.
Cost can be quite reasonable, even for ~500-1000 units.
When I was doing it RTI was known as the better of the US providers, but they also had a long wait list.
Now that I consider it I find it odd no one has attempted this before.
I think it would be easy to fill up a group buy, especially so if we offered it on Lenco Heaven as well.
Depending on various fanciness I couldn’t see it exceeding $20 or so, which is still less than half some of the modern test records go for.
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Old 10th October 2017, 10:54 PM   #14
Pano is offline Pano  United States
Pano's Avatar
Test LP group buy
It would be worth talking to the disc mastering engineers about what they see as stumbling blocks to cutting clean test signals. They should have a good feel for what will work and what won't. Cutting heads aren't perfect.
Take the Speaker Voltage Test!
Old 10th October 2017, 11:53 PM   #15
davidsrsb is offline davidsrsb  Malaysia
Half speed mastering would allow accurate sweep up to about 30kHz. Nothing currently available is accurate to 20kHz.
I was at a HiFi show in KL a couple of years ago and the Ellipson test disc sold in hundreds
Old 11th October 2017, 02:49 PM   #16
anatech is offline anatech  Canada
anatech's Avatar
Test LP group buy
L/R channel identification is handy to have in a test situation, then there is how much isolation between channels that can be measured.
"Just because you can, doesn't mean you should" © my Wife
Old 11th October 2017, 03:03 PM   #17
There are several members here that have already dealt with small run LP's and I would hope we could find an engineer that would lend a sympathetic ear toward an obsessive requirement for centering of the hole.
As for tracks one that exists on no test LP's is a reference frequency in one channel and a once per rev pulse in the other. I would recommend a single raised cosine pulse that stays inband since there are simple algorithms to place it in time exactly.
Old 11th October 2017, 03:04 PM   #18
Pano's Avatar
Test LP group buy
Yes Chris, I'd like to have channel ID and crosstalk tests.
I have no idea how much channel separation can be cut into the LP, so we'd want to ask the mastering house about that, and include that info with the test LP.
Old 11th October 2017, 03:06 PM   #19
Pano's Avatar
Test LP group buy
For the speed polar plot, right?
Old 11th October 2017, 03:22 PM   #20
anatech's Avatar
Test LP group buy
Isn't the standard frequency for speed and W&F test 3 KHz?
-Chris
Test LP group buyHide this!Advertise here!
Ultimate listening test ... test your ears and audio chain PMA Everything Else 378 21st November 2013 10:20 AM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 09:22 AM
AKSA versus modified unit, a group hearing test inside my appartment destroyer X Solid State 37 4th October 2004 09:18 PM
