Test LP group buy
Test LP group buy
Old 15th April 2018, 10:29 PM   #1391
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by billshurv View Post
Thank you.
I don't have a hard copy but the wear test is 20k, 18k, 16k, 14k, 10k and 5k tones on inner most and outer most grooves at low levels. The last audible tones on each set should be the same. At my age it's likely I would only hear the 10k and 5k. This test would clearly be better using a recording of the tracks.
The STR 120 has inner, middle, and outer groove 500-50k sweeps that show the frequency losses better.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 15th April 2018, 11:09 PM   #1392
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Test LP group buy
Ah good. I didn't think there was anything magic I had missed.
Old 16th April 2018, 01:55 PM   #1393
Yes, they don't separate the expected loss from what they call "wear loss". I found another interesting result, the sensitivity to warp/off-center seems to vary a lot with frequency and radius. I'm not sure now if the plots only looking at magnitude show cantilever resonances 20k-50k.
Old 19th April 2018, 07:04 AM   #1394
Johnny2Bad is offline Johnny2Bad  Canada
Informative paper on FemtoLaser capabilities and uses.
Maybe not vapourware after all.
Femtosecond laser micromachining: A back-to-basics primer - Industrial Laser Solutions
" ... Go back to the beginning of a technology before the priesthood was established; that was the time when people were communicating information, not proving why there needs to be Priests. This is why the old texts tend to be so good. ..."
Old 19th April 2018, 10:29 AM   #1395
billshurv's Avatar
Test LP group buy
femtosecond lasers are not vapourware. Cutting a 500m long track with one may be slightly more than has been tried before by a factor of many orders of magnitude.
Old 29th April 2018, 06:54 PM   #1396
They are proposing a bit more than that; they are saying the ceramic stampers will be laser cut as "mountains" not "valleys", so a lot of material being removed.
Assuming it works, though, they are eliminating a lot of steps in the stamping process (one stamper of ceramic > vinyl LP vs the lathe cut master > the master stamper > x number of mothers > x number of production stampers > vinyl LP).
Since this is only vaguely on-topic, I won't comment further.
Old 8th May 2018, 11:55 PM   #1397
kevinkr's Avatar
Test LP group buy
Take a look at this modern record press:
Hand Drawn Pressing on Vimeo
Hopefully you suspect what I am thinking..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th May 2018, 01:49 AM   #1398
Hearinspace is online now Hearinspace  Canada
Test LP group buy
Hi Kevin, No idea what you're thinking but watched the horse video that followed and then this other Hand Drawn vid came up.
Old 9th May 2018, 01:59 AM   #1399
So, just wondering, how close are we?
Old 9th May 2018, 07:16 PM   #1400
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
Test LP group buy
\_(ツ)_/
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Test LP group buyHide this!Advertise here!
Ultimate listening test ... test your ears and audio chain PMA Everything Else 378 21st November 2013 10:20 AM
Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy. Tea-Bag Group Buys 330 20th May 2013 01:03 PM
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 09:22 AM
AKSA versus modified unit, a group hearing test inside my appartment destroyer X Solid State 37 4th October 2004 09:18 PM
