Modifying RIAA playback for 78 rpm/45rpm
Old 29th March 2004, 11:18 AM   #1
ashok is offline ashok
ashok's Avatar
Default Modifying RIAA playback for 78 rpm/45rpm
I keep reading that it is possible to get better results with a variable RIAA playback curve for 78 rpm records. What do they really adjust ? I guess it must be the corner frequencies but by how much ?
Is this also applicable to 45 rpm plaback ?
Anyone on this forum who does these things ? Any sites that I can check out with such information ?
Thanks.
Ashok.
AM
Old 29th March 2004, 03:59 PM   #2
R.I.P.
33 RPM and 45RPM RIAA eq is the same.
78's used lots of different curves.
A MM fitted with a 78 stylus will not be right through a MM input.
Sometimes I think for 78's a ceramic cartridge that does
not require any EQ at all would be the easiest option.
sreten.
Old 30th March 2004, 09:39 AM   #3
Havoc is offline Havoc
Read and enjoy: http://www.rfwilmut.clara.net/repro78/repro.html
Old 30th March 2004, 11:57 AM   #4
ashok's Avatar
Default Thanks.
Hi Havoc and Sreten,
Thanks for the info. I think that all I wanted.
It has everything that I was looking for.
Thanks again.
Ashok.
AM
Old 16th January 2007, 02:39 AM   #5
dvautier is offline dvautier  United States
I run the ceramic 78 RPM output right into my sound card. Then I equalize as needed. when I say "as needed" I mean it. The records are wildly different depending on make, model, year and condition.
I have some web pages on this subject. The discussion under technical page may help. hope so.
http://dvautier.home.comcast.net/records/records.htm
Old 16th January 2007, 10:23 PM   #6
hagtech is offline hagtech
hagtech's Avatar
We adjust the corners and turn frequencies, just as you thought. 78s were recorded with many (dozens) of equalization curves. There are three main inflection points, one at a low frequency (50Hz for modern RIAA), a mid-band (500Hz), and upper (2122Hz). More info here:
www.hagtech.com/equalization.html
and
www.hagtech.com/pdf/riaa.pdf
I don't believe 45s have this problem, they don't go back as far. But don't quote me on that.
jh
Modifying RIAA playback for 78 rpm/45rpmHide this!Advertise here!
VHS for recording and playback? systemerror909 Analogue Source 32 2nd September 2011 08:16 AM
Playback Amp jman 31 Chip Amps 83 3rd May 2009 11:54 PM
Non oversampling CD-playback, which way should I go? stefanK Digital Source 17 25th March 2006 08:26 PM
45rpm adapter for a Rek-O-Kut N-33H mig-ru Analogue Source 0 4th April 2004 03:14 AM
Wav playback problem dhaen Everything Else 0 18th November 2003 12:53 PM
