Remove riaa stage from cheap phono pre
Old 31st December 2017, 02:49 AM   #41
gigigirl is offline gigigirl
Default Remember Crap in Crap Out
As I was correctly advised several years ago. If you want to rip LP's to a computer, only do it if you have the very best equipment, because as I said in the title Crap in Crap out.
Why don't you try using 2 (one after the other) upgraded Boozhound MC boards. These give 30dB gain so final output may be a little high depending on what cartridge you are using. But if you are not using a high quality MC don't bother.
Cheers
Old 31st December 2017, 03:18 AM   #42
Default Crap in Crap out
Why don't you try using 2 (one after the other) upgraded Boozhound MC boards. These give 30dB gain each so final output may be a little high depending on what cartridge you are using. But if you are not using a high quality MC don't bother.
Cheers
Old 9th February 2018, 09:23 AM   #43
DIP8 is offline DIP8  Italy
Good day Guys.
Pre phono boards is arrived and I must say that it also sounds good considering the price.
The 4 electroiltyc cap is 47uf 25v, but under the cap, printed on board, a write show a value of 10uf
Can I replace them with something better? like some mkp..
Thank you
Old 9th February 2018, 09:37 AM   #44
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Hard to tell without knowing the schematics...
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Remove riaa stage from cheap phono preHide this!Advertise here!
ICEPower 250ASP - For cheaps, nCore Kit eriksquires Class D 1 6th February 2016 03:42 PM
Bypass RIAA stage jiiteepee Analogue Source 12 20th December 2015 06:51 AM
New Prephono for my system.!! GUSTAV1966 Analogue Source 0 16th December 2015 08:35 AM
RIAA stage problem ... jiiteepee Analogue Source 21 14th March 2014 08:03 AM
Pass Labs PrePhono XP 25 GUSTAV1966 Pass Labs 1 6th February 2011 12:10 PM
