diy air bearing tonearm build
Old 30th August 2017, 05:58 AM   #11
lexx21 is offline lexx21  United States
I will try to draw it up and post it. Fair warning though....I have no cad skills...lol
Old 31st August 2017, 01:12 PM   #12
super10018 is offline super10018  United States
Isn’t it easy to use 1” square tube as air supply channel and 1 1/4” triangle as carriage?
Old 31st August 2017, 03:18 PM   #13
carolus is offline carolus  Belgium
1" air supply versus/& 1 1/4" carriage ..... don't match in the 90
Karel
Old 31st August 2017, 05:22 PM   #14
I see. So you cut all three triangles from one long piece of triangle
Old 31st August 2017, 05:46 PM   #15
Yes, (it's tricky), the best (& normal) way is to cut out a Alu-L-profile the air supply arm adjacent with "is" carriage.
I did so (after bad experiences ), very KIS.
Karel
Old 1st September 2017, 08:29 PM   #16
And you need to lap the slide with the piece with the holes. A 25 micron grit shoild work fine.
Old 1st September 2017, 09:07 PM   #17
Yes, after that (1 step):
2 step: do the same with "white tooth pasta" (only the white color)
3 step: clean the two pieces (air supply arm & carriage)
4 step: anodization all Alu components.
5 step: assembling the arm & carriage ...
etc.
Karel
Old 1st September 2017, 11:44 PM   #18
I would use the grit that is used to polish telescope mirrors. 25 micron grit mixed with oil would work well.
There are also sellers on ebay who sell various grit size polishing paste.
Im not sure that I would anodize the angles though. You would be adding a coating to the interface of the two pieces of metal.
Oh, drill first before lapping. Drilling will deform the metal slightly and the lapping will solve that.
Old 13th September 2017, 03:11 PM   #19
Originally Posted by Ben Culley View Post
....I am in the early throes of building an air bearing tonearm similar to the terminator design. ......
.... any progress ...... ?
Old 13th September 2017, 10:13 PM   #20
Ben Culley is offline Ben Culley  Australia
Yes thanks Carlos. Happy with my first attempt. I am working on an adjustable bracket for the up and down movement. I've also made the turntable bearing. Cheers
diy air bearing tonearm buildHide this!Advertise here!
Air bearing tonearm problem super10018 Analogue Source 16 9th June 2015 06:42 PM
Air bearing tonearm Sourdingue Analogue Source 4 31st August 2010 05:00 PM
Rega tonearm vertical bearing? kenneth Analogue Source 2 29th April 2010 02:29 PM
Help with Air Bearing Tonearm Binaural Analogue Source 5 22nd April 2009 12:43 AM
What can be done for tonearm bearing? Sunsun22 Analogue Source 4 12th September 2005 10:45 AM
