Turntable speed stabilty
Old 3rd January 2018, 03:46 PM   #841
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
I guess you haven't read back many posts. see post 823
Old 3rd January 2018, 04:00 PM   #842
super10018 is offline super10018  United States
There may be some confusions. My bad. However, putting anything between cartridge and head shell won't do the trick.
Old 3rd January 2018, 04:07 PM   #843
billshurv's Avatar
This is very true. Hasn't stopped people who should know better selling devices to do this though.
The Cartridge Man Isolator for example
Edit: And I am ignoring your comment about pivoted damping at the bearings as I really cannot afford this . SME FDIV Damper kit
Old 3rd January 2018, 07:25 PM   #844
diyrayk is offline diyrayk  United States
diyrayk's Avatar
Originally Posted by diyrayk View Post
In designing and building my own unipivot arm, I put most of the damping in the vertical direction for warp damping, and less damping in the horizontal direction, instead relying on the zero offset angle of my linear tracker to reduce FM from horizontal scrubbing.
Ray K
Originally Posted by Hans Polak View Post
Hi Ray,
Thanks for your contribution.
One question: How exactly did you put damping in the vert direction to your own arm ?
Hans
Hans,
Damping is at the pivot, not especially different from the way damping has been implemented on other unipivots. In my case it was done by selecting the dimensions of the cylindrical bearing cup (part B in the photo) thatís submerged in a silicone oil bath in the pivot base (part C in the photo). For vertical motion the cylinder sloshes the silicone bath and sees significant damping effect. For horizontal motion the cylinder rotates axially in the silicone bath and the damping effect is less. The design was done empirically, so I am unable to offer any design calculations. Basically seat-of-the-pants engineering that worked out eminently well.
Ray K
http://www.diyaudio.com/forums/attac...1&d=1515010686
If more is better, then too much is just right.
Old 3rd January 2018, 09:53 PM   #845
Hans Polak is offline Hans Polak  Netherlands
Hans,
Ray K
Impressive Ray,
thanks
Hans
Old 4th January 2018, 09:14 AM   #846
gpapag is online now gpapag  Greece
gpapag's Avatar
Default Re M97xE brush effect
Shure M97xE (on Pro-ject Debut Carbon arm) resonance test.
Brush up vs brush down
Shure TTR117 test record.
Source:
YouTube
Apply your analysis tools
brush up
Dropbox - Brush up.wav
brush down
Dropbox - Brush down.wav
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 4th January 2018, 01:43 PM   #847
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
George the analysis tool seems to have trouble labeling the low decade(s)? Getting flawless plotting of log axes especially with partial decades at either or both ends is a special exercise.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 4th January 2018, 01:46 PM   #848
Here is the first output, 5 Hz modulating 2989 Hz and 2380 Hz.
With Brush Up, waving is considerable, almost exclusively vertical resonance (not separately shown here).
Taking the brush down, suppresses the resonance and waving because of that to a great degree.
IM distortion becomes 2.5 dB less, not as much as expected when looking at the waving.
More to follow.
In the spectra below, light green is the IM spectrum and cyan the spectrum of the input signal waving caused by hor and vert resonance.
Hans
Old 4th January 2018, 02:00 PM   #849
George,
What's the lower -3dB point of your recording chain, from TT to digital.
My question is because it effects the waving of the signal in the .wav file.
Hans
Old 4th January 2018, 04:28 PM   #850
Now for 6 Hz plus both carriers at 2.4 and 3 KHz, brush up and brush down again showing IM for 3 LP revolutions.
Waving of LP input signal is again considerably lower with brush down, but with brush down IM at 5Hz is only 2.8 dB less, and still above the critical threshold of 0.1%.
Hans
Turntable speed stabiltyHide this!Advertise here!
Modifying turntable speed AlexanderN Analogue Source 11 25th October 2016 01:26 AM
Turntable speed question........ JoeDJ Analogue Source 21 28th December 2013 06:29 PM
Turntable speed billone Analogue Source 7 13th February 2012 06:20 AM
Turntable speed under load YNWOAN Analogue Source 6 5th April 2008 11:01 AM
Turntable speed diyman Analogue Source 3 23rd May 2005 06:44 PM
