Turntable speed stabilty
Old 14th October 2017, 02:53 PM   #711
Pano is offline Pano  United States
Pano's Avatar
That's an interesting way to do it.
Old 14th October 2017, 11:31 PM   #712
luckythedog is offline luckythedog  United Kingdom
Originally Posted by scott wurcer View Post
Still in many cases this give a good indication of relative speed within the accuracy of the clocks in your DAC. I got 33.375 RPM and 33.373 RPM 30 sec later.
Yes, but that misses the point that variation in pitch is far more significant to audibility than absolute pitch......... reasonably, so long as there's no gross-out....
LD
Old 15th October 2017, 12:06 AM   #713
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Simply an attempt to double check the frequency calibration.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 15th October 2017, 09:50 AM   #714
OK I get it thanks: checking absolute frequency of the recorded carrier tone on the test record.
LD
Old 15th October 2017, 02:22 PM   #715
Pano's Avatar
I thought it was just to measure how long it takes for the LP to make a full turn. At a 96kHz sampling rate, the measurement is very fine.
Take the Speaker Voltage Test!
Old 15th October 2017, 02:46 PM   #716
Yes that is true but there should be 1800 cycles of a 1kHz tone in 1.8 seconds at 33 1/3 RPM. So it is a double check on the frequency accuracy of the recorded tone on the LP. This information could be used to scale your results to as good as the clock on your DAC is.
Old 15th October 2017, 03:02 PM   #717
Pano's Avatar
Thanks, that got me thinking about a check on the Test LP. I'll post over there.
Turntable speed stabiltyHide this!Advertise here!
Modifying turntable speed AlexanderN Analogue Source 11 25th October 2016 01:26 AM
Turntable speed question........ JoeDJ Analogue Source 21 28th December 2013 06:29 PM
Turntable speed billone Analogue Source 7 13th February 2012 06:20 AM
Turntable speed under load YNWOAN Analogue Source 6 5th April 2008 11:01 AM
Turntable speed diyman Analogue Source 3 23rd May 2005 06:44 PM
Copyright ©1999-2017 diyAudio
