Turntable speed stabilty
Old 27th June 2017, 11:41 AM   #21
luckythedog is offline luckythedog  United Kingdom
Originally Posted by Kay Pirinha View Post
How did you record the angle/x axis
It's based on 'correct' time, ie the time when perfectly constant 33 1/3 rpm would present at that angle/location on the rotation. I think that's fine, even if it means there's always some error in exact angle/location - we're not that interested in finding exact position. Whereas we are interested in accurate frequency relative to real time, reasonably locally on the rotation.
LD
Old 27th June 2017, 12:14 PM   #22
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
So, e.g. in your graph from #4 the eccentricity would move in contra-rotational direction (assuming that the record is spinning a little slow) if you'd record more than one turn?
Best regards!
Old 27th June 2017, 01:54 PM   #23
Best regards!
Yes. However, in a healthy TT error is often small enough to tolerate and I try to do that. However, I also have the option to vary start point of 2nd revolution display based on average frequency of the first. This is why I only display 2 revolutions, BTW, since errors accumulate.
It's also why I standardise on 3150Hz test tones, though 3kHz is supported. Actually, pretty much any frequency would work, but to avoid this issue one has to know what the original frequency was meant to be in the first place...
LD
Old 28th June 2017, 04:42 AM   #24
Hiten is offline Hiten  India
Thanks Bill and LD.
Originally Posted by luckythedog View Post
Also, focus on accurate motor speed control is typically misplaced, IMO, because that's seldom a dominant factor in overall pitch stability, it seems.
LD
I like the idea of displaying a servo signal where there is one, if nothing else, for a health check......!
But pitch stability is only partly about platter speed stability. Typically factors like spindle centering, platter vertical run-out, warp, and cart-arm stability contribute far more in an otherwise healthy TT. So this is where bang-for-the-money is, and is well within most DIYers capabilities methinks.
LD
Kindly explain platter vertical run-out. Also what do you mean by Cart-arm stability affecting constant speed ?
TTs having good sonics are not related to pitch stability is little surprising. Do cutting lathes have perfect speed? How is it achieved ? I think beyond certain point it does not matter as much as rumble noise. But achieving it or measuring it is interesting. Do you or anyone else have polar plots of classic tables mentioned earlier ?
Thanks and Regards.
Old 28th June 2017, 04:47 AM   #25
Ok just read in other thread about Lathe speed stability. But how it is achieved ?
Regards.
Old 28th June 2017, 06:09 AM   #26
xx3stksm is offline xx3stksm  Japan
xx3stksm's Avatar
Here's FFT of my turntable PL910(kyocera late1980).Testrecord is "stereo reviiew's model sr12".When FFTsize is 32768, calculated data is about 0.3second.When 8192,about 0.085second.
I can't measure speed drift from FFT.But I suppose peak level of successive small size FFT(8192) is referrence to average turntable speed.They are fairly stable more than predicted.
Old 28th June 2017, 06:43 AM   #27
planet IX is offline planet IX  Germany
Send a message via MSN to planet IX
Some thoughts about the correlation of sonics and pitch stability...
Pitch stability is measured with a discrete frequency and amplitude, so there is a (more or less) constant drag on the motor.
I think any TT motor can handle a constant drag satisfactory.
With music playing the drag on the needle changes permanently. So maybe we should look at the dynamic behaviour of the motor and the motor controller. A testrecord with a frequency that changes the amplitude abruptly could probably give a better prediction of the sonics...
Old 28th June 2017, 12:30 PM   #28
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by planet IX View Post
With music playing the drag on the needle changes permanently. So maybe we should look at the dynamic behaviour of the motor and the motor controller. A test record with a frequency that changes the amplitude abruptly could probably give a better prediction of the sonics...
I agree on this Boris.
But also remember that there is vinyl –mat interface, mat material and mat-platter interface.
The more lossy the two interfaces are and the more compliant and thick the mat is, the more decoupled the vinyl is from the platter.
This is good for acoustic decoupling but not good for torque transfer under dynamic drag changes.
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 28th June 2017, 02:18 PM   #29
super10018 is offline super10018  United States
To LD,
Your plot is very clever and informative. I wish you can add user interface so we all can measure our own tables.
I am thinking if I can export a set of data, i.e. time and frequencies, from recording of a test tone 31Hz. Then, I may import the data into some kind of polar plot software. I may get same measurements as yours. Do you know any polar plot software I can use?
Thank you!
Jim
Old 28th June 2017, 04:09 PM   #30
msdin is offline msdin  United Kingdom
It works with any test record that provides a continuous sine tone at about 3kHz or 3.15kHz, and just needs a short recording of 10s or so in any lossless format at any reasonable level.
So, over a few years, I collected together recordings of test sample tones that people have posted on forums, but usually I don't know and it doesn't matter what the actual test record was.
I don't mind running a few examples here, if anyone likes?
The software is a set of VB modules I wrote a few years back for myself to diagnose and improve pitch stability on my rigs. I never got round to making a proper user interface, so I still have to run them them manually.
Meantime, here's another good example from the archive. This is from a Micro Seiki SX-777. Red and Blue traces are for 2 consecutive revolutions.
LD
Here is a 3150hz sample from a Phonosophie No3 turntable.
Phonosophie P3 3150Hz Tone /Phonosophie_P3_3150Hz_Tone.wav
msdin
Turntable speed stabiltyHide this!Advertise here!
Modifying turntable speed AlexanderN Analogue Source 11 25th October 2016 01:26 AM
Turntable speed question........ JoeDJ Analogue Source 21 28th December 2013 06:29 PM
Turntable speed billone Analogue Source 7 13th February 2012 06:20 AM
Turntable speed under load YNWOAN Analogue Source 6 5th April 2008 11:01 AM
Turntable speed diyman Analogue Source 3 23rd May 2005 06:44 PM
