Turntable speed stabilty
Old 26th June 2017, 09:04 AM   #11
luckythedog is offline luckythedog  United Kingdom
Hi Volken, I have an archived 3rd party 3150Hz test recording from an EMT 930, it's polar plot is attached below.
I think one can see that for this example of a EMT930, there was something big going on at a few Hz, but the 25Hz drive component was there but not prominent. It does show up in the amplitude spectrum, but not so much in the FM.
Also inset in this is the conventional spectrum, which also only hints at a 25Hz component.
I don't know what cartridge was fitted, unfortunately, but the cart-arm resonance isn't prominent either in this case.
LD
Old 26th June 2017, 06:19 PM   #12
sq225917 is online now sq225917  United Kingdom
Send a message via MSN to sq225917 Turntable speed stabilty
That's not even vaguely round, is the 930 idler driven?
I have the hifi news test record, badly centered and poor pitch on the 3150 cut. Acquiring a good din record of an optical disc as per regas dev unit is on the cards.
Paradise Pre-reg PSU PCBs
Old 26th June 2017, 10:42 PM   #13
Hearinspace is online now Hearinspace  Canada
Originally Posted by kaputt View Post
Please crank up some peer pressure so I finally try that feature
Your moniker gives you instant street cred with me!
+873.2 grams.
Old 26th June 2017, 10:58 PM   #14
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
wossat? (either the optical disk or regas dev unit).
Old 27th June 2017, 04:54 AM   #15
Hiten is offline Hiten  India
Any other method other than test records ? Since offcenter and warps can not be avoided any modern method to measure speed stability ?
A Postscript printer can print precise dots (or markings) we can make perfectly center thick white sheet with such markings and optically measure the speed variations. Right ?
How do classic tables like Thorens, Garrard, Lencos and Technics compare with regards to speed stability. Any one has measured them and have data on them ?
Regards.
Old 27th June 2017, 04:57 AM   #16
....if table is direct drive can we measure current required in motor in speed control circuits and ***** its speed stability ? Heavy platters with tight tolerance highly polished/lapped bearings will have comparatively stable speed isn't it ?
Regards.
Old 27th June 2017, 08:19 AM   #17
billshurv's Avatar
Hiten: You certainly can use a non-record method to measure things. The question then becomes what you gain and what you lose from this. My Kenwood has a 300 slot optical code wheel on the spindle that is used to provide the correction signal to the electronics. So that would give a 540Hz square wave if you probed the opto connectors.
AEDB-9140-A13 | Broadcom Incremental Encoder -0.5 ? 7 V dc | Broadcom is an example of a 500 slot code wheel with detector that is fairly cheap. You'd need to work out how to fix it in place. If you want more resolution then HEDS-6140#B09 | Broadcom 1000 Pulse Code Wheel with a 0.5 in, Through Hole | Broadcom but the cost nearly doubles as you have to buy wheel and sensor seperately. You could also on tables with a strobe marking on the platter pickup off that.
I think all of these are work investigating and comparing to the test record method.
Ref your direct drive question, the answer is yes and no. Yes you can measure current and back EMF to do magical things in DSP, but the motor is turning too slowly to really make use of it. But this is an area I would love to have time to explore further (and would require another thread).
Old 27th June 2017, 09:59 AM   #18
Yes the EMT 930 is idler drive. It's very well respected and was part of the EMT studio family that has serious heritage. I also have a test tone recording from an EMT938 in the archive that I can dig out..............
How round the polar plot appears depends upon the radial scale, and I set it to deliberately see the variations. I always use 3Hz as the spacing, because that is said to be the threshold of most people's ability to hear the difference. I try to keep the plots consistent, so there are 18 radial lines and the peak excursion clips the outside.
What we generally find, IME, is that TTs with excellent sonic reputation don't necessarily have good pitch stability when looked at this way - often far worse than those considered good or mediocre..... which is interesting and surprising at the same time perhaps?
Also, focus on accurate motor speed control is typically misplaced, IMO, because that's seldom a dominant factor in overall pitch stability, it seems.
LD
Old 27th June 2017, 11:03 AM   #19
I like the idea of displaying a servo signal where there is one, if nothing else, for a health check......!
But pitch stability is only partly about platter speed stability. Typically factors like spindle centering, platter vertical run-out, warp, and cart-arm stability contribute far more in an otherwise healthy TT. So this is where bang-for-the-money is, and is well within most DIYers capabilities methinks.
LD
Old 27th June 2017, 11:21 AM   #20
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Luckythedog,
your polar diagrams, translated into conventional xy graphs, represent the rotation angle by the x and frequency by the y axis, respectively. How did you record the angle/x axis, in order to get the x/y relationship in your diagrams?
@Hiten: Maybe you've frogotten Dual in your list of classic TT manufacturers?
Best regards!
Turntable speed stabiltyHide this!Advertise here!
Modifying turntable speed AlexanderN Analogue Source 11 25th October 2016 01:26 AM
Turntable speed question........ JoeDJ Analogue Source 21 28th December 2013 06:29 PM
Turntable speed billone Analogue Source 7 13th February 2012 06:20 AM
Turntable speed under load YNWOAN Analogue Source 6 5th April 2008 11:01 AM
Turntable speed diyman Analogue Source 3 23rd May 2005 06:44 PM
