Turntable speed stabilty
Old 28th May 2018, 01:56 PM   #1081
Hiten is offline Hiten  India
Thanks Volken. Always wanted to see measurements of Classic Vintage Turntable. How to interpret the graphs ? I presume the test track was 3K and narrower the band the more stable the speed. Right ? Original Thorens had wow and flutter measurements was 0.05%. It would be wonderfull to see Garrrads and Lencos measurements.
Regards.
Old 28th May 2018, 03:14 PM   #1082
JP is offline JP  United States
JP's Avatar
Interesting. On the polar for the MK3 there's a speed variation at 45 and 315 deg that corresponds with a noise I can barely hear at the motor - I suspect a bearing issue. I've four other MK3 I can measure so we can increase the sample pool there. Still, the R looks remarkably good.
"Show me on the doll where the aliens touched you." - SY
Old 28th May 2018, 05:30 PM   #1083
volken is offline volken  Netherlands
Regards.
Yes A 3khz testrecord with FM sidebands first tonearm/cart freq. second motor rotational speed , then belt flutter and the cursor at 100hz motor vibration.The sharp peak is a indication for speed stability very low wow fig.
Old 28th May 2018, 05:53 PM   #1084
Dave Cawley is offline Dave Cawley  United Kingdom
Dave Cawley's Avatar
When I attended the press briefing, they went on endlessly about noise floor and bearings. I wasn't convinced entirley but coupled with the review by HiFi News at http://www.soundhifi.com/images/HiFi...R%20review.pdf maybe the were dead right ?
"if it measures well & sounds good, it is good" : "if it measures badly & sounds bad it is bad" : "if it measures badly & sounds good, it could be improved" : "if it measures well but sounds bad it is bad"
Old 29th May 2018, 11:37 AM   #1085
Thanks and regards.
Old 2nd June 2018, 06:04 PM   #1086
JP's Avatar
Here's a different MK3:
Dropbox - sp10mk3-2-wf-sa7.wav
Turntable speed stabiltyHide this!Advertise here!
Modifying turntable speed AlexanderN Analogue Source 11 25th October 2016 01:26 AM
Turntable speed question........ JoeDJ Analogue Source 21 28th December 2013 06:29 PM
Turntable speed billone Analogue Source 7 13th February 2012 06:20 AM
Turntable speed under load YNWOAN Analogue Source 6 5th April 2008 11:01 AM
Turntable speed diyman Analogue Source 3 23rd May 2005 06:44 PM
