I made a xtal oscilo (cd 4060) for 200hz. I divided this 4 times (cd 4013) and the ouput is at the end 50Hz (Europe).I use leds.
A regular neon bulb with a normal disk and the mains frec (sinus 50hz) work well, but not with my digital 50% duty cycle signal.
I add a simple low-pass filter and it seems something better.
¿There is a special "strobe disk" for digital "long" signal?
or.... maybe use a 100 or 200 hz?
Cheers.
Cheers.
I found.This is one of them:
https://www.elmelectronics.com/wp-content/uploads/2016/07/ELM440DS.pdf.
20mA of output current power directly the led. I don't know how cheap is it and it easiness to get it.
Maybe like this?
Use your existing circuit, minus one of the 4013 sections so you have a 100Hz square wave with 50% duty cycle. Add a 74123 one-shot circuit like the PDF attached. 1K5 with 1uFd should give you a 500µS pulse width (5% duty cycle). Making R1 smaller will decrease the on-time of the LED.
Thank´s .
http://sudomod.com/forum/viewtopic.php?f=13&t=332
See the reset (400 hz) at the pin 10 (cd 4013) to short the duty cycle.
Thank´s .
120Hz LED Turntable Strobe in Altoids Tin - sudomod
Ahh! Very clever. No additional parts and you can go down the divider chain if you need a shorter on-time.
I tried it yet ... and now it works very fine, more better as the old neon bulb.
With the 400hz ( pin 2 from cd 4060) reset in the last 2xdivider (pin 4 2nd D-flip-flop) the final frequency is 100hz and the positive (flash-photo) duty cycle pulse is only 12.5%.Not 50%.The "photo" in any strobe disk is very clear.
I need anything.Very happy.
Thanks for yours recomandations.
Cheers
Cheers
- Analogue Source
- Strobe disk for a digital signal?
