Lehmann Audio Black Cube SE II question
Old 18th May 2017, 10:43 PM   #1
mdelrossi is offline mdelrossi  United States
Default Lehmann Audio Black Cube SE II question
Hello all,
I have a lehmann Audio Black Cube SE II that had a blown channel.
Got the replacement opamp THAT 1510. When I went to replace it there was a resistor across pins 1&8 only on one channel.
This is supposed to set the gain, but wouldn't there be one on both channels?
BTW it sounds balanced
thanks
mdr
Old 18th May 2017, 11:04 PM   #2
rayma is offline rayma  United States
Are you sure? The two channels seem to be laid out the same.
Is a resistor is missing in one of the footprint positions?
http://www.audiocostruzioni.com/r_s/...I/dett%202.jpg
Old 18th May 2017, 11:55 PM   #3
Definitely, the resistor was soldered to the backside of the pcb ( bottom)
Old 19th May 2017, 01:13 AM   #4
If one resistor is really missing, you should install one that matches the other channel.
Is there any sign that one was soldered in place and removed, or are the pads solder free?
If one was never installed, you should tell Lehmann about this, they'll appreciate it.
Old 19th May 2017, 06:27 AM   #5
Calvin is offline Calvin  Germany
Calvin's Avatar
a resistor on the bottom is certainly a modification not present in the original.
The fixed MM-gain resistor between pins 1 and 8 of the THAT chip is a 220R 1% metal film.
A second resistor of 22R can be switched via Dip-switch pos1 of SW101/201 for the higher MC-gain.
The only off-the-shelf modificatioon on the PCB bottom side are the two soldered wire bridges that put the input stage into unbalanced mode.
jauu
Calvin
Old 19th May 2017, 02:09 PM   #6
Thanks for all the replies.
Upon further investigation the power supply isn't balanced. one side outputs 15v the other side 15.4. the higher side is where the resistor is attached to the back of the PCB.
Attached is the closeup of the adjusting resistors for the power supply.
one side is 120 and 1.3k the other is 240 and 2.7k. this doesn't make much sense.Click the image to open in full size.
Here is the top of the Cube , all resistors match side to side
Old 19th May 2017, 02:40 PM   #7
Underside of PCB 2.9k?
Old 19th May 2017, 04:41 PM   #8
Calvin's Avatar
iIrc the datasheet of the LM317/337 regs shows feedback resistor values around 240R-270R and around 2k5-3k3 for the upper feedback resistors.
The set of 120R/1k3 results in similar output voltage, but represents probabely not the original values.
The soldering of the modded gain resistor looks very non-professional ... heck even the casings of both(!) nearby Dip switches are molten.
jauu
Calvin
Old 19th May 2017, 05:33 PM   #9
jauu
Calvin
ooops, my bad soldering angle on resistor and dip switches
But the resistor didn't look that much better before I replaced the opamp.
Any idea on why the values are so far off? Other than a mistake?
do you think they tried to compensate for the added voltage with the extra resistor on the back?
I'll order a few resistors that should conform better too the data sheet.
Or should I get a multi turn pot, and dial it in?
thanks
mdr
Old 19th May 2017, 06:26 PM   #10
Calvin's Avatar
I don't know why the second set of resistors is lower in value .... maybe those resistors had been flying around.
For that added bottom side resistor .... it looks as if the colour code would read brown-white-black-red-violet, hence 19k 0.1%.
Paralleled with the original 220R the difference in gain is probabely only measurable but sonically irrelevant.
Still though I'd rather change back to the original state.
jauu
Calvin
Lehmann Audio Black Cube SE II questionHide this!Advertise here!
SOS... problems with Lehmann BCL ("Lovely Cube")... Miky2011 Solid State 2 31st October 2011 10:53 PM
FS: Lehmann Audio Black Cube MM/MC Phonostage enjoythemusic1 Swap Meet 0 27th August 2010 04:27 PM
Lehmann Black Cube Phono Stage mg16 Swap Meet 1 14th April 2008 04:22 PM
Black Cube Phono original not se mg16 Swap Meet 0 10th April 2008 10:31 PM
Black Cube Power supply mantisory Analogue Source 0 20th September 2007 01:50 PM
