Playing With Panasonic Strain Gauge Cartridges (And A Dedicated Phono Stage)
Old 27th November 2017, 04:04 PM   #451
super10018 is offline super10018  United States
Originally Posted by kevinkr View Post
Yes that is the right circuit, but you only need one in the PSU between the chassis and the PSU board. You can connect the audio supply ground to the chassis in the audio chassis or run a separate ground wire which could be connected to the chassis in the PSU. (No connection between audio power ground and chassis in the audio chassis if you do this.)
Note also that only ONE ground pad on each of the pre-amp cards should be connected to the PSU. I use the one associated with the 300V supply.
Finally the ground loop breaker goes between the PSU chassis and the PSU ground.
I got it. Thanks!
Old 27th November 2017, 06:20 PM   #452
ra7 is offline ra7  United States
After recently reading up on strain gauge cartridges (actually, it was one of Kevin's posts that piqued my interest, so thanks Kevin!!), I pulled the trigger on an ebay offering of Panasonic EP451C and the matching demodulator to go with it. When it arrived, it was in absolutely mint condition. It even came with a Walco diamond stylus.
I just got it hooked up last night and it was quite impressive. The response still needs some shaping. I'd say it is pretty close to the attached image, which is the response of the cartridge itself. I put a shelf of -6 db, Q of 1, at 15 kHz. That cleaned up the etched sound at the top. Left the bottom end as it is, which was quite pronounced and probably needs a cut also.
My system is a Technics SL1200 with a DL103 and a Dyna 10X5. The 10X5 is superior to the DL103, and I'd say the 451C was not far behind the 10X5. It definitely calls for more experimentation.
I haven't looked at the circuit of the demodulator, but it does not appear to compensate for the cartridge response. It did sound fine otherwise, so, it must compensate for the RIAA plus inherent SG response. How can one run a frequency response sweep? Might be time to invest in a test LP.
I feel like this technology has a higher ceiling than the MC cartridges and probably at a fraction of the cost. Apart from the tonal response, the imaging was very good, and there was a general sense of ease about the sound.
I'm going to try to build Hazard's JFET preamp to see what it can do, and might even try Kevin's circuit, though I don't have any experience with tubes. I think another viable approach is to just provide gain and do the correction digitally, for example, using a miniDSP. That would make it flexible so that you can correct the cartridge's response together with all the other correction.
Old 1st December 2017, 02:42 AM   #453
shooter is offline shooter  United States
We have a get together today to listen to the new strain gauge preamp, everyone that knows my system were impressed with the improvement over the old and commented the sound was the best my system ever sounded! I end up using .12 uf vitamin q and 1 uf polycarbonate as coupling caps. Very happy with the sound! Very quiet as well.
Kevin really did an outstanding job designing this preamp, for those that are on board for the build you won't be disappointed!
Old 5th December 2017, 02:38 AM   #454
kevinkr's Avatar
Thank you for the feedback!
I am in the process of getting ready to have one of my OEM styli retipped with a microridge stylus on a boron cantilever for use on my 465C.
Next up after that will be the 451C on the Souther Tri-Quartz.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th December 2017, 12:23 AM   #455
I think the boron microridge stylus will be the best, the boron line contact sounds a bit warmer but the sapphire microridge extracts more detail may be the boron microridge will have the best of both!
Old 6th December 2017, 07:18 PM   #456
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Differences between Namiki micro-ridge and line-contact profiles.
Old 6th December 2017, 11:36 PM   #457
kevinkr's Avatar
Interesting and a bit counter-intuitive. I wonder if the microridge is a lot less sensitive to SRA than the line contact? Everything else the same?
Old 7th December 2017, 12:48 AM   #458
AVWERK's Avatar
The micro ridge has more contact area overall but the line contact is a wider than the thin micro ridge
Lookup- Adamant microridge
down on the bottom hit stylus tip for specs
David
Old 7th December 2017, 02:00 AM   #459
kevinkr's Avatar
Interesting...
Old 8th December 2017, 07:37 PM   #460
DaveG is offline DaveG  United States
yes, I agree..very interesting reading. thank you AVWERK
Playing With Panasonic Strain Gauge Cartridges (And A Dedicated Phono Stage)Hide this!Advertise here!
Sound Smith Strain Gauge Phono Preamp Johnloudb Analogue Source 24 17th December 2017 05:43 PM
FS Strain Gauge Cartridge Nat Panasonic EPC-451C with New Stylus Santa Claws Swap Meet 1 31st July 2015 05:46 PM
strain gauge Enochrome Analogue Source 21 22nd March 2015 11:49 PM
Panasonic Strain Gauge Cartridge 451 II New Unused calvert73 Swap Meet 8 21st September 2013 12:10 AM
Strain Gauge pickups woody Analogue Source 2 10th April 2004 02:48 PM
