Trafomatic RIAA network. Any good? - diyAudio
Old 9th May 2017, 09:38 PM   #1
JordiMB is offline JordiMB  Spain
Default Trafomatic RIAA network. Any good?
While studying different RIAA deemphasis sistems (because learning is fun) I've found this phono stage that uses a different aproach:
6moons audio reviews: Trafomatic Audio Reference Phono One
The RIAA network is neither in the feedback path nor in the classic passive filter between stages. It's in the plate load. Maybe some of you were aware of it, but for me it's the first time I see something like this. Well, it makes sense, and it seems to work allright.
I've made a very quick simulation on LTSpice, using jfets instead of tubes, and with some tweaking of resistors and capacitors values I've obtained a decent result (not accurated, just promising). What it can be appealing is that you lose a lot less signal than with a passive filter.
Can it be a good alternative system, or has it been tried before and has it been rejected for not being good enough?
Old 9th May 2017, 10:27 PM   #2
analog_sa's Avatar
Check out the last circuit in this thread
:: View topic - Pentode Phono
It is about the only way to build an entire phono preamp in a single stage. Having listened to a proto based on the idea i can attest to its viability. In fact it was remarkably good.
The idea is of course not new. Historic phono preamps have been built using frequency dependent loaded pentodes. If not mistaken one of Creek Audio's phono stages employed the same idea using transistors.
Old 10th May 2017, 03:41 AM   #3
PRR is offline PRR  United States
PRR's Avatar
Electrically it is the same thing.
With triodes it is dubious because internal plate resistance is not known exactly. With pentodes the internal resistance is generally so much greater than the external DC resistor that we can work with resistor-based accuracy.
Old 10th May 2017, 04:45 AM   #4
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Dht Rob built it and recommended it to me. So I'll build one...
Sent from my Nexus 6P using Tapatalk
Old 10th May 2017, 06:52 AM   #5
Interesting. That's the reason they used pentodes. Worth exploring, even you can use jfets or mosfets...
Old 10th May 2017, 07:24 AM   #6
analog_sa's Avatar
Is it? The frequency dependent load never allows full swing at high frequencies as it controls the gain. Overload performance cannot be equal.
Old 10th May 2017, 09:33 AM   #7
From what I've seen in the simulation, you don't lose as much gain as with the classic passive filter. So maybe it's possible to make a phono preamp with only one gain stage. Interesting what analog_sa says: this kind of riaa network can prevent from overload at high frequencies, no?
Old 11th May 2017, 12:55 PM   #8
DF96 is offline DF96  England
If you use a voltage amplifier with low output impedance (e.g. a triode) then you need to add a series resistor to define the source impedance, then add the RIAA network.
If you use a transconductance amplifier with high output impedance (e.g. pentode or cascode) then you need to add a shunt resistor to define the source impedance, then add the RIAA network.
I can't see much difference between these two approaches. With the latter you may have to be more careful about PSRR because you probably want to take your final output voltage referenced to ground but the pentode version uses the supply rail as reference.
Old 12th May 2017, 07:29 PM   #9
analog_sa's Avatar
Another great example
Schematic riaa corrector
Old 12th May 2017, 07:35 PM   #10
analog_sa's Avatar
And another from forum member Wavebourn
Linearity
RIAA network adjustment Sempati Tubes / Valves 33 30th April 2015 08:33 AM
RIAA Network Position payloadde Tubes / Valves 97 3rd October 2014 09:39 AM
Re- calculating RIAA network limono Tubes / Valves 12 11th July 2014 11:46 AM
RIAA Network Transfer Function BRSHiFi Software Tools 23 28th March 2012 02:09 PM
caps for RIAA network GAK Parts 2 8th February 2004 11:05 PM
Copyright 1999-2017 diyAudio
