Budget tube phono stage - diyAudio
Old 15th February 2017, 08:16 PM   #1
Default Budget tube phono stage
I'm looking for suggestions on what I could build for a decent bang for the buck phono stage to use with a 5 mv output moving magnet cartridge. I picked up my SL-1300, AT 440MLA for $250 total so I don't want to spend a fortune on the phono My preamp also has additional gain so something in the +/- 40 dB range is fine.
I am guessing the power transformer will be the most expensive single part? So if a design is proposed and there is something that is off the shelf Edcor or equivalent I am sure that will help in keeping cost down.
Not looking for dirt cheap if it's going to hamper performance, so all around good value to performance is what I'm looking at. Thanks!
Valve itch caught my eye, anyone have a rough estimate how much that would be to build? I don't need a step up transformer since the cartridge is high output. And I have plenty of scrap metal and could bang together a wood case.
Old 16th February 2017, 10:11 AM   #2
lexx21 is offline lexx21  United States
What are you thinking of as "budget"? My 6dj8 phono preamp could be thought of as budget by some, but the quality of parts that I used ran around 300 bucks or more........the transformers, caps, two hv regulator boards, the filament regulator...then the parts for the preamp itself. Good connectors cost 7-10 each and then there was the military type screw on connector for the umbilical between the power supply and preamp.
Budget is all relative....need to be specific.
Old 16th February 2017, 10:20 AM   #3
It can't be more simple:
https://www.onsemi.com/pub/Collateral/AND8177-D.PDF
Old 16th February 2017, 11:01 AM   #4
indianajo's Avatar
I've got a tube mm preamp, I've got a op amp mm disco mixer. Right now the disco mixer sounds better. Cost about $35.
The tube preamp went trebly and brittle when one of the 1961 paper caps failed & I replaced ten of them with polyester 0.22's. Waiting to buy $5.60 each polyprophyene caps (takes two 0.1 uf parallel to make 0.2 uf) plus the time to do that again. Meanwhile I'm listening to the disco mixer 4-10 hours a day. Plus advantage of the mixer, I don't have to walk around the table to switch the input selector and turn the volume knob when I go from LP to CD to FM radio or back again. Also mixer volume knobs are not exotic hard to buy 250k log stereo pots. $12 freight on that 250k pot, and I had to call in & do a repeat order since they shipped a mono pot the first time. Had to go to the post office & ship the mono back. PIT*
Also the disco mixer uses 1/20th the mains energy than the tube preamp. Less A/C used to cool the room in the summer.
Go ahead build the tube mixer. Listen to a op amp preamp while you're building.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 16th February 2017, 09:53 PM   #5
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Look on diyaudio for Mini-me or phonodude.
Phonodude koifarm edition
Or from sound and comfort mm phono stage just the sound stage.
Old 16th February 2017, 10:40 PM   #6
kevinkr's Avatar
Have a look at Salas Valve Itch phono here:
Valve Itch phono
Alternatively there is also my Muscovite Mini III here: The Muscovite Mini III (6N23P) Phono Stage
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Tube phono stage build creeve Tubes / Valves 26 16th November 2016 05:29 PM
Phono stage design considerations part 1: choosing 1st stage tube Joshua_G Tubes / Valves 207 5th March 2016 01:07 PM
Tube Phono stage dilema velvetsunrise Tubes / Valves 27 9th June 2013 10:41 AM
valve phono stage on a budget rauza1 Tubes / Valves 4 17th April 2011 03:37 PM
tube phono stage dsavitsk Tubes / Valves 10 15th December 2006 01:26 PM
Copyright 1999-2017 diyAudio
