Jerry T's Stablizer
Jerry T's Stablizer
Old 16th March 2004, 08:13 PM   #1
mpm32 is offline mpm32  United States
Default Jerry T's Stablizer
Nice piece of work Jerry and thanks for the cad drawing. Can you explain how it works?
It has eight smaller grooved rods sitting around a cental core that are held in place by rubber o-rings?
This sits on the TT pin.
Does the compression of the o-rings on the central core do anything other than hold the small rods in place?
Does it compress the "pin" hole in the central core for a tighter fit?
I think I can replicate in brass if I get those questions answered.
Thanks,
Mark
Old 16th March 2004, 08:59 PM   #2
R.I.P.
Certainly looks very nice.
But having over the years tried nearly every variation
of the theme I generally don't use anything, though
I do still have a rubber friction fit clamp.
Of the devices I tried certainly the "best" is the screw
type clamp that uses a washer under the centre hole
and a screwdown clamp that flattens the record ( via
cantilever action ) against the the mat surface.
A system also used used on the Oracle I believe.
Very fiddly though, but the best.
Second best is probably combined edge and centre weights.
I just feel I should caution heavy centre weights on
their own don't work that well as they tend to lift up
the edges of a record (one of its ways up at least).
sreten.
Old 16th March 2004, 09:04 PM   #3
Jerry T. is offline Jerry T.  Netherlands
Jerry T.'s Avatar
Thanks for the compliments.
The measurments on the drawing are in millimeters.
As the picture shows, the 8 outer rods are held in place by 2 O-rings 55mmX3.5mm (55mm is inner diameter). And that is all there is to it!
Make sure that the diameter 30.3mm of the core, and diameter 19mm are spot on for a perfect fit.
Most pins are about 7.1mm diameter so a hole of 7.3mm diameter is good enough.
Now, ain't that grand !
Old 16th March 2004, 09:05 PM   #4
Jerry T.'s Avatar
Here's a bigger picture of the stabilizer.
It weighs about 500 grams.
Old 17th March 2004, 08:13 AM   #5
Jerry T.'s Avatar
sreten.
Lift up the edges of a record?
Old 17th March 2004, 09:29 AM   #6
Raka is offline Raka  Europe
Raka's Avatar
Yes, if the "hole" that accomodates the label of the record is deep enough.
What is beyond the speaker?
Old 17th March 2004, 11:41 AM   #7
R.I.P.
Raka is right, (I was assuming a label "well" in the mat)
With a flat mat it won't lift the edges of a record, but given the profile
of an LP the inner grooves would not be in contact with a hard flat mat.
sreten
Old 17th March 2004, 12:28 PM   #8
Jerry T.'s Avatar
I'm using a felt mat.
The stabilizer's weight (500 grams) is distributed to the 8 rods on the outside. So in a way you have 8 "stamps" of 62.5 grams pushing down on the record in a diameter of 70mm.
Old 17th March 2004, 12:41 PM   #9
R.I.P.
Hi JT,
I was just advising caution,
sometimes things don't work the way you expect.
On a felt mat above a flat platter your stabiliser should work well.
With a hard mat with a label recess (like mine)
results would be more difficult to predict.
sreten.
Old 17th March 2004, 01:21 PM   #10
Jerry T.'s Avatar
Hi JT,
sreten.
Sreten,
No problem, i just wanted an explanation, so i gave you the facts.
Oh, Mark you wrote that you wanted to make one of brass. Make sure you putt some kind of coating or lacquer on it, because if you don't, you'll go crazy from the fingermarks on it.
Jerry T's StablizerHide this!Advertise here!
