| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
light emitting amplifier.
i was talking 2 a friend about electronics, and i told him of a thing called Light Dependent Risistor, a.k.a LDR. and the it struck me. i think i have my work cut out for me, but check the idea on wicth i think my light emitting amplifier is based on. tell me what u think. is it already invented? is it operational with low distortion(with a buffer)? if it had been invented, what is it called? am i on to somthing? |
#3 |
The basic device is called an opto-isolator.
I believe they can amplify with the version where the LED provides the base current of of an isolated transistor. Without the isolation requirement they have little use in normal circuits, standard circuitry performs better. sorry again....... sreten.
#4 | ||
i added a pic. not working. hmm. Quote:
oh well, at least u dont lie! |
#5 | |
Electrons are yellow and more is better!
This analogue optocoupler consists of one LED and two photo transistors. One of the is used for feedback for the LED. None of these opto solutions produces any high fidelity but they work alright for industrial purposes.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
Used for optical compressors. The input drives the led, and the ldr is used to reduce the gain of the output.
#7 |
Seems what Your talking about, electro samurai, is a vactrol, a led and a ldr in the same casing. Found in several guitaramps. A realy lousy component. Also notice that all ldr´s have "memory" that is they adjust to variations in light slowly, faster action on increasing than decreasing lightintensity. This is a fun to play with component for efectboxes for instruments and such but useless in reproductve amplificarion
Ingvar |
#8 |
its seems as there are many names 4 this silly divice.
indeed silly. the compressor idea sound cool. ill check it out. thx 2 all that responded. |
#9 | |
Since the opamp in the servo is a photodiode (large capacitiative surface area) the amplifier it is pretty easy to get it to oscillate, care must be taken in compensation -- by the way -- the next big thing will be in using the wasted base current to generate light -- I believe that IBM had a press release to this effect 3 or 4 weeks ago. |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Page generated in 0.11524 seconds (72.59% PHP - 27.41% MySQL) with 10 queries |
