mechanical resonance in MMs
Old 24th April 2018, 01:16 PM   #1601
anatech is offline anatech  Canada
anatech's Avatar
Hi Bill,
Could you run another single wire for ground through the arm? They must have grounded the arm at the pivot end, so that shouldn't need work.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 24th April 2018, 01:26 PM   #1602
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
The SIII has the connector at the pivot end not trivial to add a wire. I need to check if there is metal to metal contact inside the plastic connector. It is a kooky design.
Old 24th April 2018, 04:04 PM   #1603
anatech's Avatar
Hi Bill,
Hopefully you will find something you can ground a wire to and simply run another to the headshell. This would allow you to remain fully balanced.
-Chris
Old 24th April 2018, 04:14 PM   #1604
billshurv's Avatar
yeah. This one is a challenge tho.
Old 24th April 2018, 04:17 PM   #1605
anatech's Avatar
Hi Bill,
Yuck, that one looks near impossible!
I have one thing to say to you on this. You did buy it.
-Chris
Old 27th April 2018, 03:20 PM   #1606
billshurv's Avatar
I wanted this. It's close to the ultimate low mass high compliance combination that the late 70s produced. Total effective mass 4.5g. Wonderful pointless madness. It does look nice tho.
Also in my research (although no intention to buy another cart at the moment) I found the technics EPC-205II L. This is a low inductance version made 73-76 and has the somewhat incredulous spec of 40mH and 30R for the coil. So 2L-R works. This could be a candidate for the lowest noise MM front end using a transamp. two tens of a gnatfart improvement is pointless, but fun to find the limit
Old 28th April 2018, 05:07 PM   #1607
ThomasA is offline ThomasA  Sweden
Interesting thread, I have not been able to go through it all. With respect to test records, there is really a need for better ones:
Dropbox - Test records and frequency response measurements.pdf
Old 28th April 2018, 05:25 PM   #1608
billshurv's Avatar
We have a thread on test records as well. It's currently in cat herding mode, but we hope to get something eventually
Old 28th April 2018, 05:31 PM   #1609
I noticed that... so much to read.
Old 28th April 2018, 05:32 PM   #1610
billshurv's Avatar
Sorry about that, we've had a lot to discuss. Bit like Ents
mechanical resonance in MMsHide this!Advertise here!
MMs / BL = dynamics? chazdrumzalot Full Range 70 31st March 2018 12:39 PM
Mechanical Sectioning .vs. Silicon dots for resonance control bolserst Planars & Exotics 39 21st January 2017 11:05 PM
APR12 Mms - accurate? Pallas CSS 1 10th April 2012 02:07 AM
Mms to Mmd calculations jaya000 Multi-Way 2 9th February 2009 07:48 AM
Mmd Vs Mms Elbert Multi-Way 5 7th October 2008 07:54 PM
