What would you want to see in a book on electronics for vinyl replay? Douglas Self.
Old 8th December 2016, 10:06 AM   #11
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
A historical section regarding earlier speeds and 'house' eq curves and circuit/software DSP solutions for those interested in transcribing old recordings would be useful.
Nigel Pearson could likely assist you here.
Dan.
Old 8th December 2016, 03:10 PM   #12
DouglasSelf is offline DouglasSelf  United Kingdom
DouglasSelf's Avatar
Originally Posted by jan.didden View Post
I see a lot going on in vinyl replaying in these pages, especially on DSP supported RIAA eq. Some heavy hitters active there.
So I believe such a dedicated book should include these concepts for sure.
Jan
Hello Jan
Me too, though I have no plans to get into the details of the DSP code. I am aware of Scott Wurcer's article in Linear Audio 10.
Seems to me the best way might be to implement the RIAA HF rolloff in analogue, to maintain good HF headroom and cut down ultrasonics that might cause aliasing, convert to digital, and then do the LF-boost in DSP with as much precision as required.
Douglas Self
Old 8th December 2016, 03:16 PM   #13
Originally Posted by Bigun View Post
If you want to be complete, you may want to look at the mechanical aspects of vinyl reproduction as they seem to be as critical as the electrical. I'm not sure if you are comfortable or expert enough to cover them or if a guest author for such a chapter in the book could cover that.
I claim no special expertise in the mechanical area. So far as I can see at present, sticking purely to the electronic aspects of vinyl is going to give quite a lengthy book.
I don't know what is already in your small signal book, but there are other small signal analogue sources that folk are interested in - tape being the one that comes to mind.
I plan to point out that tape heads are the other transducers (apart from MM carts) that benefit from load-synthesis, or 'electronic cooling' if you prefer. Perhaps we are having a multitrack revival, but tape seems a bit off-topic to me.
Douglas Self
Old 8th December 2016, 03:30 PM   #14
Originally Posted by billshurv View Post
What I think is missing from publications I have seen is a section on calibration, by which I mean working with the limitations of the transducer to get a flat response (and alluded to in a response to you in another thread). As you pointed out there are variances side to side as well as between units and the blunt tools of a fixed resistance and variable capacitance are a recipe for peaky HF response.
Hmmm. But how to do it? The data acquisition could no doubt be done by a PC, but you would need to buy an expensive test record. I will ponder this, but I'm not sure I can add much to what Burkhard Vogel has done.
And extending what Jan said, looking at the HF spectra of click, ticks pops and scratches to see what can be done to reduce those in preparation for A/D conversion is another area that has little coverage in current publications.
Now I have plans for that. I have been looking hard at ultrasonic filtering with the avoidance of A-D aliasing in mind.
Douglas Self
Old 8th December 2016, 03:33 PM   #15
Originally Posted by bondini View Post
If a book on vinyl replay included a handy compendium of fundamental electro+mechanical information, maybe I could retire my shelf-load of papers and articles. Less time rummaging through Van den Hul’s FAQs, Peter Copeland’s excellent “Manual of Analogue Sound Restoration Techniques”, less time hunting for that Shure technical note by Happ, wondering where I’ve put Ladegaard’s B&K application note ... you get my drift.
I would echo Bigun’s request for a systematic treatment of the mechanical (and perhaps electro-mechanical) aspects of replay.
I think the mechanical stuff needs a separate book. And I don't think I am the man to write it. Maybe someone else would like to have a go?
My thanks for the responses so far.
Douglas Self
Old 8th December 2016, 04:52 PM   #16
kevinkr's Avatar
Sounds intriguing to me, I'd definitely pick up a copy.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 8th December 2016, 05:09 PM   #17
djmiddelkoop is offline djmiddelkoop  Netherlands
djmiddelkoop's Avatar
how to determine correct loading of a cartridge
Yes, and this must cover the capacitive loading also.
Procedures on how to align the cartridge mechanically with the help of testrecords like :
Analogue Productions-The Ultimate Analogue Test LP-Turntable Set Up Tools|Acoustic Sounds
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 8th December 2016, 05:45 PM   #18
Onvinyl is offline Onvinyl
Onvinyl's Avatar
What would I consider as an USP would be a discussion of engineering and calculating an input stage for a phono amp. I mean, which electronic company today would say 'let's invent an active device for the folks who construct phono stages'. Rather, w e see those devices discontinued (those famous japanese FET's for instance).
So, what we do today is 'hacking' modern devices for ancient purposses, be it singles Q's or integrated circuits.
I'm not sure if I made myself clear, anyway...
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 8th December 2016, 06:02 PM   #19
ChicagoJTW is offline ChicagoJTW
Mr. Self:
I enjoyed the first edition of your book.
Digital capture of vinyl output is very poorly documented in my experience. There are a number of phono preamps that output digitized signals. As the last of the cassette tape makers vanishes, the ability to easily preserve (and sometimes in the process, manipulate) records on tape is disappearing also. The software I have used (Audacity, mostly) is very cumbersome.
I realize this may be considered ancillary to electronic reproduction of recorded grooves, but a discussion of digitized vinyl versus CDs, MP3s and cassettes with noise reduction would be most enlightening.
Old 8th December 2016, 06:02 PM   #20
Conrad Hoffman is offline Conrad Hoffman  United States
I agree on some historical perspective, including the various RIAA circuits that have been used in the past and typical performance. You already have some of that in the current book, but an expansion would be nice. Maybe cover some popular preamp and receiver models over time.
Also agree on calibration and measurement. IMO accurately measuring RIAA response isn't a trivial matter and no matter how much I read about noise, accurate practical measurements seem to be elusive and suffer from limitations of filters, meters and other equipment that I can afford.
I may be barking up the wrong tree, but at least I'm barking!
What would you want to see in a book on electronics for vinyl replay? Douglas Self.Hide this!Advertise here!
Douglas Self's Active Crossovers book forr Analog Line Level 14 11th April 2018 10:45 PM
Hypothesis as to why some prefer vinyl: Douglas Self DouglasSelf Analogue Source 1130 23rd March 2018 08:54 PM
book-audio power amplifier by Douglas Self mikee12345 Solid State 12 6th January 2018 09:57 AM
Book : Small Signal Audio Design - Douglas Self dearchap Analog Line Level 21 16th February 2016 05:39 PM
New Douglas Self Book blmn Solid State 7 22nd July 2009 06:00 PM
