update existing TTs or save pennies for a new setup?
Old 16th March 2004, 09:17 AM   #21
diyAudio Member RIP
I'm no expert on motors, but an incorrect capacitor
value will not affect speed as far as I know.
AFAIK you need two phases 90 degrees apart for a
synchronous motor, and the capacitor is for phase
shifting.
I've read if they are not 90 degrees you get more
vibration, but I don't really know.
Replacing the capacitor/capacitors seems like
a very good idea to me for an old turntable.
sreten.
Old 16th March 2004, 09:34 AM   #22
Raka is offline Raka  Europe
Raka's Avatar
Well, I work in a motors company, but I'm not an expert either
It doesn't change the speed, but can do it with the torque, so the slip changes, so does (slightly) the speed.
What is beyond the speaker?
Old 26th March 2004, 04:01 AM   #23
Daniel-A is offline Daniel-A  Canada
Hi
Don't trow money into sony or pioneer junk turntable. Buy or built a real turntable.
i used to have a "high end" pioneer record player. Lot of tics and pops.
finaly decide to buy a used Oracle Delphi 4. Result: the lp must have to be in really bad shape to hear noise with the music. It's even better than my cdp.
Daniel-a
Old 28th March 2004, 12:33 PM   #24
g13092 is offline g13092  United States
Thanks Daniel-A, but I can't throw in the towel just yet. I'm tinkerer & learning alot from these decks. I've come to the conclusion that it's worth messing around with these for now as I have nothing to lose if I wreck one of these. Maybe down the road I'll get into a higher end machine.
I will admit that the sony is a bit cheap in some respects (plastic base, not so heavy platter), but I haven't given up on it yet. I am learning quite a bit about setup & tweaking, even with this seemingly cheap deck. If I could find out what the proper compliance rating is (no manual), I could match up a resonably priced pickup. Right now I have a pickering TL-3 for which I do not know the specs, I have no idea if it's right for the arm. Mainly, this deck will be used with the computer for transfers to CD.
The pioneer is a well made deck with a good bearing. If I can get the speed right & get the arm set up well (or swap in a decent arm, Grace 707 or RB250), it should be adequate for my existing system. Again, learning quite a bit from experimenting with this table.
Old 29th March 2004, 04:01 AM   #25
hi q!
good idea to use them as learning tools.
Always a good idea to learn ( i'm a teacher!!!)
Daniel-a
Old 23rd April 2004, 12:10 PM   #26
LuvPioneer is offline LuvPioneer  Australia
Hi Mark !
Have you sorted out that drama with the Pioneer PL-41 TT as yet.
Please let me know.
Manfred
Old 27th April 2004, 02:35 AM   #27
Well, the table has been completely disassembled & is awaiting a pulley that a friend is machining. This will mate to the maxon motor I plan to adapt to the original motor mounting plate. Then I can evaluate belt aligment & get the motor mounted. I also have a maxon motor controller that should be able to dial in the desired speeds.
Meanwhile, I obtained a grado green on ebay & I am breaking that in on my sony DD table. So far, it sounds great compared to any of the previous carts I have had around here. Eventually, I'll find an arm for the Pioneer (Grace 707?) & get it all back together.
md
Old 27th April 2004, 04:27 AM   #28
i'm glad to read what you're doing to learn. i'll wait for any follow up^
Daniel
Old 11th May 2004, 07:37 PM   #29
Cambe is offline Cambe
Hello Everyone,
I have a Pioneer PLC-590 turntable with a Mission 774 tonearm mounted. The arm needs new cables for the counter weights. I have been thinking about finding someone who ties fishing fies to
make them. I don't have the arm's instructions anymore so I really
don't know the length it should be.
Sincerely,
Cambe
Old 20th July 2004, 08:56 PM   #30
sev is offline sev  United States
hi mark,
I have the same problem with my pl-41! (plus: I have a fairchild 412 that is running too slow. just my kind of luck...).
how is it going with the pioneer? could you fix the problem?
please let me know.
regards,
sev.
update existing TTs or save pennies for a new setup?Hide this!Advertise here!
Trying to save my Onkyo 504 amp Minicooper Solid State 3 4th September 2009 04:21 PM
way to save a thread Robert McLean Everything Else 5 17th September 2008 11:54 AM
DJ Needs to Save Money dirtyk777 PA Systems 22 14th October 2006 07:11 PM
Aleph-x help me save it. anders.a Pass Labs 47 13th July 2006 06:46 AM
Scrap or save? Burnedfingers Tubes / Valves 11 6th September 2003 05:33 PM
Copyright ©1999-2017 diyAudio
