microphone splitter box - Page 2 - diyAudio
Old 11th March 2004, 11:54 PM   #11
It should not interfere with the main mix either, provided your input impedance is a couple of k-ohms or more. (In my experience, sound quality isn't exactly a major point in average venues either....)
... thanks for the tip...
the inserts are usually switched jack points, with send on tip and return on ring. In case you use this, use stereo jacks and connect your + wire to both tip and ring, - ground as usual
thanks for that tip too, I've actually done this before!
Well I found a local manufacturer that does transformers for mic splitters, at about half the price of the jensen's. (Harbuch in Sydney.)
Active splitter PCB jessestack Vendor's Bazaar 1 7th November 2015 01:46 PM
Is this a phase splitter? tom-vdl Solid State 9 15th October 2009 08:21 PM
VGA splitter Rookie Parts 1 17th September 2004 03:54 PM
Splitter for S/PDIF Ryssen Digital Source 3 29th December 2003 11:44 AM
Copyright 1999-2017 diyAudio
