| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
For the Vinyl friends some pictures of my turntable.
This Device is a result of several years on building-research-rebuilding. Feel free to coment. |
#2 |
Top view
#3 |
Base
#4 |
Well you said "feel free to comment".
My hacksaw would be at the arm mounting arms like a shot, but I presume you want the option of mounting longer arms. Personally I'd give this up . The Alphason is really nice. sreten.
#5 |
Looks great!
Is the bearing and platter homemade as well? what's the red thing under the motorpod?
Keep an open mind. It helps. Peter |
#6 |
What material is used in the base???
#7 |
A work of art. That red thing looks like one of those fancy optical bench up/down tables. Is this a permanent need? Any info on the motor and supply?
#8 |
Some answers and thanks for the coments
My hacksaw would be at the arm mounting arms like a shot, but I presume you want the option of mounting longer arms. Yep! My 15' DIY arm is still in construction. Is the bearing and platter homemade as well? what's the red thing under the motorpod? The bearing is made on a profesionell tool machine by a friend at Schütte .The platter is made by a friend at Bayer and finaly the red thing is a "Swiss Boy 110" from Rudolf Grauer AG (second adjustabile arm base?!?). What material is used in the base??? Polymer concrete made in one casting Any info on the motor and supply? Case is Transrotor with Papst AC motor (standard) with simple transforner Source for Phillips Dc motor (Linn LP12,Platine Verdier) ????? "The red thing" |
#9 |
This is a pasteup from another thread....
Let's make a DIYAUDIO TT This page #10 also gives details on a US Maxxon motor suitable for the task This is the motor from the original "Platine Verdier" For European TT builders it might be easier to get motors from this company in Holland..' http://www.premotec.com/product_catalogue.html The CL series ( 29 or 40 series ) should be very good for the task, being Coreless DC motors . These are the motors used in "Le Platine Verdier". Originally it was made by Philips so I guess Premotec is a Philips offspring.... BTW-- do you have a german source for the polymer concrete??? |
#10 |
Hi Posthorn, really nice work!
Maxon motors are actually easy to get in germany. I just bought one, as i plan to change the drive-unit of my Scheu-TT from string-drive to tape- drive. Hopefully it will be completed within the next weeks- you are welcome to have al look at it; I live in cologne too. Regards, Boris |
| Looking for a turntable | bgatlin | Swap Meet | 1 | 15th December 2005 08:52 PM |
| New turntable | rocknroll | Analogue Source | 5 | 9th January 2004 05:52 PM |
| Page generated in 0.12137 seconds (73.66% PHP - 26.34% MySQL) with 11 queries |
