Old 23rd October 2016, 01:45 AM   #1
eimis is offline eimis  Europe
Default Little Bear T8 MM/MC Phono gain modification
So I'm trying to use the Little Bear T8 phono, but the gain is a bit too low with the Grado cart I use. Which resistor should I replace and what value? I can read schematics but my knowledge basically ends there - not sure which resistors are best to replace. Please advise
-t8-png
Did my best with the schematic, this is only the right channel, MM signal path. "In" is where cartridge connects, "Out" is the RCA output...
Old 23rd October 2016, 01:53 AM   #2
rayma is offline rayma  United States
and what value? 470uf each.
You could try bypassing the source resistors of the two gain stages.
Ai least 100uF to 470uF across each of the two 680R should help.
You can eliminate the input coupling capacitor, it isn't needed.
The jfets are usually shown "upside down" compared to this drawing.
Old 23rd October 2016, 02:05 AM   #3
Haha.. Well those caps were the ones I omitted from my diagram! Now it's the full schematic:
-t8-png
So I guess nothing else can be done to increase gain as the capacitors are already 470uf?
Old 23rd October 2016, 02:11 AM   #4
Each of the two gain stages would have to be redesigned for somewhat higher gain.
This might require different jfets and resistor values.
Old 23rd October 2016, 02:13 AM   #5
Waly is offline Waly
-t8-png
You may increase a little RR8 and RR14.
Old 23rd October 2016, 02:19 AM   #6
Well I was only thinking of replacing some resistors as I really haven't got the knowledge to redesign it. Will play with RR8 and RR14 tomorrow...interesting
Old 23rd October 2016, 02:40 AM   #7
Don't increase them very much, or the second stage will more easily clip half of the waveform.
Perhaps you could get away with as much as 5.1k for each. This should increase the overall gain
by something like 4dB.
Old 6th December 2017, 09:01 PM   #8
TUBBER is offline TUBBER  Netherlands
Did you eventually succeed to improve the gain? I bought this phone preamp and i was looking for the schematic. it was nowhere to be found but you made it yourself. Thank's fout that. I am prettig disappointed with this amp. It sounds dull and flat.
JFET MM/MC Phono Preamp schillg11 Solid State 3 17th October 2016 12:42 PM
Sentec PP9 phono MM/MC preamp JohanB Solid State 1 1st March 2015 04:23 AM
Phono MC/MM who is running balanced? Bksabath Analogue Source 28 1st September 2011 03:16 PM
MC/MM Phono Pream PCB gabrielbecheanu Tubes / Valves 3 9th October 2010 09:11 AM
